Hi all,
Would you please help me to dig reason of these series of problems which caused hard crash and help to avoid this in the future.
It should have been normal heavy camera copter gimbal pitch axis tuning test flight, gimbal roll axis was locked. Flight ended to unpowered power lines and crashed. I got footage from copter and helmet camera. Log file is attached. Firmware is V3.1.2 (ddd4d881).
What happened: copter was on ALT HOLD when I noticed that left stick was mechanically stuck so that YAW worked only to right side. Throttle was fine. Radio has done this earlier but I assumed reason to be a stone I found from stick bottom. Perhaps it wasn’t. This flight was certainly last for this 9XR radio.
After realizing stick problem I was trying to switch STABILIZE and land but logs tells opposite, APM was switched to RTL. Most likely this was human error. Copter was just above the launch.
When RTL was activated, copter took of high speed away from launch, spinned one full round to left (stick was stuck to center-right) and then boosted to power lines.
This leaves one very good question:
Why and where copter boosted when RTL was activated.
I have done earlier vibration test with unbalanced propels and it has been very smooth. And after that propels are balanced. Also compassmot is done and it gave result 13%. Current is high 100A-140A on normal flight but compass and GPS are about 100mm from power cables and more from ESC:s. ESC:s are calibrated and compass declinations entered manually. Every setting in APM is like it has been on earlier flights. AUTO flight settings I haven’t touched.
One thing is what might be related to problem but I can’t be sure. Compass wasn’t in its place after crash, like pretty much any component on top of the copter because it dropped upside down. Why I’m wondering this is that compass was only glued in its place and were waiting plastic screws to arrive. I have checked its firmly in place prior to every flight but this is in theory possibility that compass is teared off. One full round to left was a thing why I’m wondering this because I couldn’t have done it. But I can’t find any proof for this from logs. I wish it was a problem and therefore is easy to solve and avoid in the future.
Video: dropbox.com/s/tn4weeot43grt … launch.mp4
In the end, no one get hurt and crash offered good opportunity to rebuild few things better which I have found during building . Price of the crash after full immediate disassembly was: full reassembly, all carbon booms, test bench result 7 motors, 6 propels, one main plate, one battery and something I haven’t found yet.
