first to give thanks to the ardu community for make help to the users and integrators.
We need to solve a simple question.
In copter, the fences work ok to us.
by we have some question:
in all manual, and auto modes, the fences works ok. but in RTL mode, the fences dont works. If the RTL trajectory intersects the loaded fence, it will be breached like fence are disabled.
there is normal?
thanks
in that case, we need to use rally points to get the drone never can breach the assigned fence for regulatory mandaments.
Have you tried “smart RTL”?
This roughly traces back the flight path from the start to find a safe way home and avoid objects between the drone and home. Works with objects, should work with no fly zones as well.
