How I can avoid RTL mood after the mission is end like if I want to crash the airplane?? ,
I try to put last waypoint with - altitude but still it’s go to rtl mood and it’s recoverable
You can always set the last WP in your mission to be a Loiter_Unlimited which will circle that point at a designated altitude. Mission Commands — Plane documentation
If you want to crash the plane then look at setting up AFS. It can do some failure based terminations (crash) or you can change a parameter while its flying to get it to crash. Advanced Failsafe Configuration — Plane documentation
Thank you very much, I will try it
