I am having problems using RTK/GPS Injection via NTRIP. If I supply credentials to our local service I seem to get a connection. The input data rate shows ~1Kb/s but the output data rate remains zero. Valid messages are seen but very intermittently and obviously the vehicle does not achieve an RTK Fix.
The interesting thing is, if I connect using rtklib’s str2str using the same credentials and have it setup a TCP server forwarding the same data over a local port, I can connect quite happily in MP using the ‘TCP Client’ option. In this case, everything seems to work as it should with reasonable in/out data rates, the expected message counters ticking over and ~30 odd satellites show up. Most importantly, I obtain an RTK fix on the vehicle.
It seems that there may be an issue with MPs NTRIP implementation?’
Here is my connection string: ntrip://xxx:xxx@positionz-rt.linz.govt.nz:2101/TRNG00NZL0
NTRIP connection:
TCP Client connection using the same source (via str2str):
Here is approx 30s of RTCM data from this source (RTCM 3.2):
LINZ_RTCM_TRNG00NZL0.log (50.3 KB)
