RPM Measurement — Copter documentation (ardupilot.org)
I cannot read sensor data and cannot control the throttle automatically according to the settings. What should I do?
my helicopter is 700N
Please describe which sensor are you using and how is it wired.
Post a param file of your setup.
Are you using the OEM beastX sensor and did you set it up for hall effect as the page you linked describes?
