hi eveyone i would like to ask regarding RPM reading. i found that after 1000hz the RPM data in autopilot jumps to a number which does not correspond to the rpm value from the esc. i am using t motor flame esc. i am not sure if this is a bug or a reading uper limit of 1000hz attached the comparison:
First thing I would look at is if there is any noise on the Rpm wire out of the esc. Your table suggests you have an oscilloscope. I would put that on and look at the trace for noise
i understand that the noise might cause false readings but actually the rpm stay constant at that value ± 50 after 1.010 Khz so might that still be regarded as an a error caused by noise? additionally i want to ask is thier actually a upper limit in the code? or not?
