I would like to connect the rpm out from my Hobbywing Platinum V3 ESC to PWM6 on my Omnibus F4 V3 to measure and log RPM.
The ESC puts out a valid 3.3V signal if not connected to the FC.
The signal disappears as soon as connected to the FC.
I assume the PWM6 is still configured as output.
I have set the following parameters following the Wiki.
Do you know what type of signal the ESC is sending?.
I think it’s a PWM, so you need to change the input to that. http://ardupilot.org/copter/docs/parameters.html#rpm-type-rpm-type
In any case, it’s worth sticking a scope on the output and see what type of signal it’s sending.
(Edit! I should learn to read…you did have set to PWM…still worth testing what type of signal you’re getting).
Oh hang on.
You need to use the GPIO pins for this. These are typically channels 9-14, depending on board. I’m not sure that the Omnibus F4 has any GPIO pins.
Also what do you mean by frequency signal? If it’s not a PWM signal, then it needs to be set to 2.
I have asked here if it’s possible to measure rpm with controllers other than pixhawk.
I assume if a pin is PWM or GPIO depends on the firmware, not hardware.
Every rpm sensor sends a frequency signal, not pwm.
Here is what the manual of my ESC says:
【Output Port for RPM Signals】
• Platinum V3 series of speed controllers have independent output ports for RPM signals.
• Specification for interface signals: It is the periodic signal with duty ratio of 17%, and 0V for low level, 3.3V for high level.
• It represents the electric rev of the brushless motor (electric rev means the rev of a 2-pole brushless motor). And here is the formula used for converting the actual rev of multi-pole brushless motor into the
electric rev of 2-pole brushless motor:
Electric rev = Actual rev of the multi-pole brushless motor × Pole number ÷2
E.g. the actual rev of a 12-pole motor is 5000rpm, so its corresponding electric rev is: 5000 × 12 ÷ 2 = 30000rpm
