Rplidar A2M12 not working
Hi
Recently i wanted to make obstackle avoidance useing RP lidar. I didn’t find any A2M8 version, so I bought A2 M12 one. I follow configuration on wiki and I changed required parameters.
  • SERIAL2_PROTOCOL] = “11”
  • [SERIAL2_BAUD]= “115”
  • [PRX_TYPE]= “5”
  • [PRX_ORIENT]= “0”
It’s connected to uart 1. I have tried swapping Rx and tx. But there is completely no response. I’m mission planner, in tab proximity visualization i have no reading and there is non stop preflight check distance sensor. Also from power requirement bec supports up to 2A.
Can I make it work? Funny story, but chatGPT suggested connecting rplidar through USB :smile:
Firmware;
-ardupilot v4.2.0
Hardware:
-Kakute H7 V2
-RPlidar A2m12
I am facing same issue. please if you find the solution tell me
You need to change the source code to add support for that particular model, recompile, upload and test.
So it’s basically not suported?
