Rover turns or spins in circles at first Waypoint in Simulator Auto Mode
When in Simulator Auto Mode, the Rover goes to WP1 and turns in a circle. Looking through past posts for solutions references to Skid Steer settings are not in the latest rev of MP Rover of Config Full Params. If I change the circle radius to 0 it simply spins in place until I disarm. I don’t see any reference circles in the Waypoint Planner to change. I am fairly certain it is a settings issue as it happens in the latest STABLE version of Rover type. The issue is over 10 years old and I am hoping for a settings solution.
Please advise.
Choose rover-skid from the dropdown menu before starting the simulation.
Do not change the servo output selections after starting the simulation (unless you are developing code to support changed outputs).
Thank you again. That worked.
Can you point me on how to setup “Save WP” on a radio switch use them?
https://ardupilot.org/rover/docs//common-learning-a-mission.html
Your so good. I’ll put you in for a raise.
I also had a similar issue with SITL and rover skid, when invoking ArduRover.exe from the command line. My rover-skid would spin in circles instead of going to the first waypoint. My fix was including the .tmp file that Mission Planner automatically passes to the ArduRover.exe as the --defaults flag.
TLDR: rover-skid from command line required --defaults=“…” flag to not go in circles. I am happy I found the solution but any ideas on why?
Hi @frmssmd,
I suspect the issue is what Yuri_Rage has outlined above. The ArduPilot configuration (e.g. parameters) do not match the physics of the simulator. E.g. the AP rover code thinks it’s driving a skid-steering rover and thus providing left and right motor outputs but the simulator is setup as a throttle-steering vehicle. They need to match or AP can’t control the simulated vehicle
