Rover-4.6.0-beta6 has been released for beta testing and can be downloaded and installed using the GCS’s beta firmwares links. Alternatively it can be manually downloaded from firmware.ardupilot.org
The changes vs -beta5 are in the Release Notes and copied below:
- Board specific changes
- ARK FPV, LumenierLuxF765, MicroAir743, StellarF4v2, X-MAV-AP-H743v2 OSD Type defaults fixed
- BETAFPV-F405-I2C UART6 fix
- BrotherHobby F405v3 and H743 support
- FlywooF405HD VTX power pin fixed
- NarinFC-H7 support
- TBS Lucid H7 Wing support
- TBS Lucid H7 support for both I2C ports
- Driver bug fixes and enhancements
- DroneCAN semaphore bug fixed which affected MPPT battery and Serial-over-CAN
- GPS logs altitude above ellipsoid instead of undulation
- GSOF GPS protects against port misconfiguration
- UBlox GPS configuration sped up
- Lua script battery monitor failures that could cause hardfaults fixed
- Nova GPS undulation fix
- Proximity backends increased to 5
- SCHA63T IMU temperature reporting bug fixed
- Plane specific fixes and enhancements
- Circle mode terrain alt handling fixed
- Fence re-enable after fence breach fixed
- Prevent rotation pitch calculations from running post-rotation
- Takeoff leveloff timeout check added
- Terrain guided target intermediate alt handling fixed
Copter SCurve navigation fix to avoid excessive vertical speed when passing through waypoints
Rover circle mode and QuickTune support smaller vehicles
Bug Fixes and minor enhancements
- AHRS initial orientation fixed when autopilot mounted in non-default orientation
- AIRSPEED mavlink message health flags fixed
- CAMERA_FOV_STATUS message always sent (once requested), attitude is earth-frame and FOV can be decimal numbers
- DDS / ROS2 fix to provide clock_gettime only on ChibiOS boards
- Lightware I2C and HC SR04 fixed timestamp for last reading (should only affect AP_Periph devices)
- “No ap_message for mavlink id” warning removed
- Power brick2 valid flag fixed on some boards
- Pre-arm check that gyro read rate is at least the main loop rate
There will still likely be one more release (e.g. -beta7) to resolve an issue with the LD19 proximity sensor but besides that, this beta6 release is likely very very close to what will be in the official release so all testing is greatly appreciated!
