Rover-4.6.0-beta5 available for beta testing!
Rover-4.6.0-beta5 has been released for beta testing and can be installed using MP or QGC’s beta firmwares links. Alternatively it can be manually downloaded from firmware.ardupilot.org
The changes vs -beta4 are in the Release Notes and copied below:
Changes from 4.6.0-beta4
  1. Board specfic changes
  • MFT-SEMA100 compass orientation fix
  • SpeedyBee F405 AIO support
  1. Driver bug fixes and enhancements
  • Bdshot locking issue fix for slow boards that could cause the flight controller to crash
  • BMP280 barometer error handling during init improved
  • CADDX gimbal RC update rate fixed
  • Hexsoon 77G and 24G radar support
  • IE FuelCell generator data rate increased
  • IIS2MDC compass support
  • LD19/LD06 proximity sensor data length sanity check fix
  • RC output cork/push fix to avoid potential motor knocking
  • SBF MosaicX5 packets with invalid length ignored
  • SPL06 barometer accuracy improvements
  • Ublox M10 configuration fix
  1. Plane specific fixes and enhancements
  • Tiltrotor motor check fixed used in throttle control handover from VTOL to forward flight
  • Improved QAssist and VTOL mode recovery from bad attitudes
  • Fixed rudder output in VTOL modes
  • Added fix for indecision in the roll controller close to inverted
  • Ensure tiltrotors use consistent fixed wing and VTOL rates
  • Clear inverted control flag on Q-mode entry
  • Auto-deploy landing gear on all fixed wing landings when enabled
  • Prevent learning bad ARSP_RATIO values when not flying
  1. Rover specific fixes and enhancements
  • Lua bindings for Follow mode
  • WATER_DEPTH mavlink message rate fix
  1. Parameter description improvements
  • ADSB_LIST_ALT param desc improved
  • Alphabetised type params for CAN, Mount, OptFlow, Proximity, Rangefinder, Serial Manager
  • Copter’s battery failsafe action gets “Brake or Land”
  • LOG_FILE_BUFSIZE units fixed
  • MOT_THST_HOVER range fixed
  • SERIALx_BAUD value added for PPP networking
  1. Bug Fixes and minor enhancements
  • Arming check for EKF3 velocity innovations
  • Copter’s LOG_BITMASK includes PIDs by default
  • DO_SET_ROI_LOCATION mission command support
  • MCU min/max voltage logging fix
  • MIS_OPTION parameter handling fixed
There will be one more beta but we’re getting close so all testing and feedback is greatly appreciated!
I don’t think I’m using any of the recent bug-fix items, but I just swapped my mower over to a CUAV Pixhawk v6X and loaded beta5. A couple hours of runtime has been successful, including MAVLink2 over Ethernet.
I do still wonder if we can either improve pivot turn navigation (or eliminate it without fuss, as discussed before). I avoid pivots in all recent firmware using the PSC nav controller.
Hi @Yuri_Rage,
Thanks for testing and reporting back!
Leonard, Rishabh and I are looking into adding support for arc mission commands in Copter and Rover so this might be a solution.
I’m happy to disable pivot turns by default if everyone agrees.
I’ve been looking at improving the pivot turn controller, but no success yet. In looking at the logs, there does seen to be a bit of a discontinuity in the commanded yaw rates when the rover switches from the pivot controller to S-curve navigation.
Agree with this
Keen to be involved in this :slight_smile:
Ran for 2 hours yesterday - had some weirdness in several acute turns to a waypoint. I was, however, messing with waypoint size - went from 1 to 3 meters.
Will revert back to 1 meter and repeat this week.
I see no difference from the beta4 other than what I’ve likely complicated.
Thanks for the hard work on improving this awesome kit!
Hi @marblecreek,
Thanks very much for the testing and feedback!
Also, pilot error on the acute turns - relocated my gps antennas, new measurements…
