Hi
after reading the WiKi I have a coule of questions for a FB heli.
If H_RSC_MODE is set to 2, the Pixhawk does everything and supplies through the PWM value that you have entered in the heli setup. The system arms like a quad, hold throttle low and to the right. how do you disarm the system after you land? if you hold low throttle (collective) and left rudder the heli is going to piroette because the throttle is still on the governor? or it will disarm itself in 10 to 15 seconds with collective low. so, how do I shut down the motor after I land in mode 2 ?
If H_RSC_MODE is set to 1, After the system is armed and spools up (ramped by Pixhawk or ESC), it pases through the PWM signal set by the reciever. It can be modifed and turned off after landing. but, if the system looses radio contact, (transmitter turned off or long distance waypoint flight) will the Pixhawk maintain the last PWM signal, or will the throttle go to zero and the heli crash? is it counting on the recievers failsafe for throttle PWM?
If H_RSC_mode is set to 0, complete bypass of Pixhawk controller with the exception of the need to arm for the collective to function. More for standard convential Heli flying and radio connection or radio failsafe setting is mandatory for ESC setpoint.
Also,
I read in another post that the flybar mode had a bug with the ACRO mode. Cyclic would not function in acro mode is this still the case?
Thanks again, getting close to that first flight, there is a lot of material to digest.
