Rotating cube on Pixhawk
Hello guys,
I’m working on a plane and I was wondering if there was any way I could change the forward direction of tmy Pixhawk 2.1 and still be able to fly it normally.
Thank you,
Smallboy808
Thank you Matt_C,
I’m very sorry for the misleading title. I forgot to change it. Thank you for the advice. When you said that it is for advanced users, how advanced do you have to be? I’m kind of starting out in this area. I also want to mention that I’m using Mission Planner. Where could I find that param so I could change it? Again, thank you very much for responding!
Yes it is possible to do, you do not need to be an advanced user. But you do need to redo all the calibrations after changing that parameter.
