I am unable to force starting point at the the when I have rotated mapping polygons.Please see the attached, how do I get around that?
Thanks in advance
Di
Thanks in advance
Di
can you upload the grid file?
also what version of MP are you running. please try the same things with the current beta. I did make some changes recently to do with this.
Hi Michael
Thanks for reply once again. OOps i cant upload Mission planner here. i will past the text below. Sorry if there is a way to upload the mission files I do not know.
MP V 1.3.41 build 1.1.6110.31287
I do not know how to obtain the beta, and can I use beta reliably for carrying out actual missions?
Thanks
Di
QGC WPL 110
0 1 0 16 0 0 0 0 -3.111431 32.216568 8.220000 1
1 0 3 184 8.000000 1700.000000 1500.000000 45.000000 0.000000 0.000000 0.000000 1
2 0 3 22 20.000000 0.000000 0.000000 0.000000 0.000000 0.000000 30.000000 1
3 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.136060 32.228510 250.000000 1
4 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.136442 32.228269 250.000000 1
5 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
6 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.161536 32.212495 250.000000 1
7 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
8 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.161919 32.212255 250.000000 1
9 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.161213 32.211052 250.000000 1
10 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.160830 32.211292 250.000000 1
11 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
12 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.135756 32.227055 250.000000 1
13 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
14 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.135373 32.227295 250.000000 1
15 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.134687 32.226080 250.000000 1
16 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.135069 32.225840 250.000000 1
17 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
18 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.160124 32.210090 250.000000 1
19 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
20 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.160506 32.209849 250.000000 1
21 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.159800 32.208647 250.000000 1
22 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.159418 32.208887 250.000000 1
23 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
24 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.134383 32.224625 250.000000 1
25 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
26 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.134000 32.224865 250.000000 1
27 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.133314 32.223650 250.000000 1
28 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.133696 32.223410 250.000000 1
29 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
30 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.158711 32.207685 250.000000 1
31 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
32 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.159094 32.207444 250.000000 1
33 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.158387 32.206242 250.000000 1
34 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.158005 32.206482 250.000000 1
35 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
36 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.133010 32.222195 250.000000 1
37 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
38 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.132627 32.222435 250.000000 1
39 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.131941 32.221220 250.000000 1
40 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.132323 32.220980 250.000000 1
41 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
42 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.157299 32.205280 250.000000 1
43 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
44 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.157681 32.205039 250.000000 1
45 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.156975 32.203837 250.000000 1
46 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.156592 32.204077 250.000000 1
47 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
48 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.131637 32.219765 250.000000 1
49 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
50 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.131254 32.220005 250.000000 1
51 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.130568 32.218791 250.000000 1
52 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.130950 32.218550 250.000000 1
53 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
54 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.155886 32.202875 250.000000 1
55 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
56 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.156268 32.202634 250.000000 1
57 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.155562 32.201432 250.000000 1
58 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.155180 32.201672 250.000000 1
59 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
60 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.130263 32.217335 250.000000 1
61 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
62 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.129881 32.217576 250.000000 1
63 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.129194 32.216361 250.000000 1
64 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.129577 32.216120 250.000000 1
65 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
66 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.154474 32.200470 250.000000 1
67 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
68 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.154856 32.200229 250.000000 1
69 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.154150 32.199027 250.000000 1
70 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.153767 32.199267 250.000000 1
71 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
72 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.128890 32.214905 250.000000 1
73 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
74 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.128508 32.215146 250.000000 1
75 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.127821 32.213931 250.000000 1
76 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.128204 32.213691 250.000000 1
77 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
78 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.153061 32.198065 250.000000 1
79 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
80 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.153443 32.197824 250.000000 1
81 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.162625 32.213457 250.000000 1
82 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.162243 32.213697 250.000000 1
83 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
84 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.137129 32.229484 250.000000 1
85 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
86 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.136746 32.229725 250.000000 1
87 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.137433 32.230940 250.000000 1
88 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.137815 32.230699 250.000000 1
89 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
90 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.162949 32.214900 250.000000 1
91 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
92 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.163331 32.214660 250.000000 1
93 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.164038 32.215862 250.000000 1
94 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.163655 32.216103 250.000000 1
95 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
96 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.138502 32.231914 250.000000 1
97 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
98 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.138120 32.232155 250.000000 1
99 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.138806 32.233370 250.000000 1
100 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.139188 32.233129 250.000000 1
101 0 3 206 102.666664 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
102 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.164362 32.217305 250.000000 1
103 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
104 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.164744 32.217065 250.000000 1
105 0 3 206 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
106 0 3 20 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
107 0 3 189 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
108 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.109888 32.208009 80.000000 1
109 0 3 16 0.000000 0.000000 0.000000 0.000000 -3.110681 32.212215 35.000000 1
110 0 3 21 0.000000 0.000000 0.000000 0.000000 -3.111254 32.215648 1.000000 1
I fact I have the Beta.
to get the grid file.
open the grid interface, and press control-s, and send me the contents of that file.
this way I can replicate your setup.
I know how to do that, but when i upload here, the file type .WAYPOINT or .TXT is not accepted.May be I’m not doing the right this to upload.
just copy and paste the contents. I can deal with that no issues.
I did. paste content above.
you pasted the mission file, not the grid file.
Right my mistake, apologies. Please see below
#saved by Mission Planner 1.3.41
-3.15268568661817 32.1995544433594
-3.12911770428839 32.2138023376465
-3.14025899859304 32.2326850891113
-3.16391242886316 32.2181797027588
that looks like a polygon file, not the *.grid file.
the grid file starts with xml at the start
