ROS2 STIL not working because of DDS
My environment is
  • Ubuntu 22
  • ROS2 humble
  • ArduCopter 4.5.7
I followed the instracution to use ros2 to launch STIL with
ros2 launch ardupilot_sitl sitl_dds_udp.launch.py transport:=udp4 refs:=$(ros2 pkg prefix ardupilot_sitl)/share/ardupilot_sitl/config/dds_xrce_profile.xml synthetic_clock:=True wipe:=False model:=quad speedup:=1 slave:=0 instance:=0 defaults:=$(ros2 pkg prefix ardupilot_sitl)/share/ardupilot_sitl/config/default_params/copter.parm,$(ros2 pkg prefix ardupilot_sitl)/share/ardupilot_sitl/config/default_params/dds_udp.parm sim_address:=127.0.0.1 master:=tcp:127.0.0.1:5760 sitl:=127.0.0.1:5501```
I got the error
```shell
  [INFO] [launch]: All log files can be found below /home/mscroboticslaptop19/.ros/log/2024-12-04-17-15-21-776656-HP-EliteBook-640-14-inch-G9-Notebook-PC-62311
  [INFO] [launch]: Default logging verbosity is set to INFO
  namespace:
  transport:        udp4
  middleware:       dds
  verbose:          4
  discovery:        7400
  port:             2019
  refs:             /home/mscroboticslaptop19/ros2_ws/install/ardupilot_sitl/share/ardupilot_sitl/config/dds_xrce_profile.xml
  command:          arducopter
  model:            quad
  speedup:          1
  slave:            0
  sim_address:      127.0.0.1
  instance:         0
  defaults:         /home/mscroboticslaptop19/ros2_ws/install/ardupilot_sitl/share/ardupilot_sitl/config/default_params/copter.parm,/home/mscroboticslaptop19/ros2_ws/install/ardupilot_sitl/share/ardupilot_sitl/config/default_params/dds_udp.parm
  synthetic_clock:  True
  command:          mavproxy.py
  master:           tcp:127.0.0.1:5760
  sitl:             127.0.0.1:5501
  out:              127.0.0.1:14550
  console:          False
  map:              False
  [INFO] [micro_ros_agent-1]: process started with pid [62312]
  [INFO] [dds_udp.parm --synthetic-clock -2]: process started with pid [62314]
  [INFO] [mavproxy.py -3]: process started with pid [62316]
  [dds_udp.parm --synthetic-clock -2] Setting SIM_SPEEDUP=1.000000
  [dds_udp.parm --synthetic-clock -2] Suggested EK3_DRAG_BCOEF_* = 16.288, EK3_DRAG_MCOEF = 0.209
  [dds_udp.parm --synthetic-clock -2] Starting sketch 'ArduCopter'
  [dds_udp.parm --synthetic-clock -2] Starting SITL input
  [dds_udp.parm --synthetic-clock -2] Using Irlock at port : 9005
  [dds_udp.parm --synthetic-clock -2] bind port 5760 for SERIAL0
  [dds_udp.parm --synthetic-clock -2] SERIAL0 on TCP port 5760
  [dds_udp.parm --synthetic-clock -2] Waiting for connection ....
  [micro_ros_agent-1] [1733332521.812663] info     | UDPv4AgentLinux.cpp | init                     | running...             | port: 2019
  [micro_ros_agent-1] [1733332521.813446] info     | Root.cpp           | set_verbose_level        | logger setup           | verbose_level: 4
  [dds_udp.parm --synthetic-clock -2] Connection on serial port 5760
  [dds_udp.parm --synthetic-clock -2] Loaded defaults from /home/mscroboticslaptop19/ros2_ws/install/ardupilot_sitl/share/ardupilot_sitl/config/default_params/copter.parm,/home/mscroboticslaptop19/ros2_ws/install/ardupilot_sitl/share/ardupilot_sitl/config/default_params/dds_udp.parm
  [dds_udp.parm --synthetic-clock -2] Home: -35.363262 149.165237 alt=584.000000m hdg=353.000000
  [dds_udp.parm --synthetic-clock -2] Smoothing reset at 0.001
  [dds_udp.parm --synthetic-clock -2] bind port 5762 for SERIAL1
  [dds_udp.parm --synthetic-clock -2] SERIAL1 on TCP port 5762
  [dds_udp.parm --synthetic-clock -2] bind port 5763 for SERIAL2
  [dds_udp.parm --synthetic-clock -2] SERIAL2 on TCP port 5763
  [dds_udp.parm --synthetic-clock -2] Waiting for internal clock bits to be set (current=0x00)
  [dds_udp.parm --synthetic-clock -2] validate_structures:513: Validating structures
  [mavproxy.py -3] Connect tcp:127.0.0.1:5760 source_system=255
  [mavproxy.py -3] Log Directory:
  [mavproxy.py -3] Telemetry log: mav.tlog
  [mavproxy.py -3] Waiting for heartbeat from tcp:127.0.0.1:5760
  [mavproxy.py -3] AP: Calibrating barometer
  [mavproxy.py -3] Detected vehicle 1:1 on link 0
  [mavproxy.py -3] online system 1
  [mavproxy.py -3] STABILIZE> Mode STABILIZE
  [mavproxy.py -3] AP: ArduCopter V4.5.7 (2a3dc4b7)
  [mavproxy.py -3] AP: 0f7772b4a1384aa8ac6ac462e66decf5
  [mavproxy.py -3] AP: Frame: QUAD/PLUS
  [mavproxy.py -3] AP: Barometer 1 calibration complete
  [mavproxy.py -3] AP: Barometer 2 calibration complete
  [micro_ros_agent-1] [1733332524.258066] info     | Root.cpp           | create_client            | create                 | client_key: 0xAAAABBBB, session_id: 0x81
  [micro_ros_agent-1] [1733332524.258108] info     | SessionManager.hpp | establish_session        | session established    | client_key: 0xAAAABBBB, address: 127.0.0.1:28335
  [mavproxy.py -3] Init Gyro**Received 1390 parameters (ftp)
  [mavproxy.py -3] Saved 1390 parameters to mav.parm
  [mavproxy.py -3]
  [mavproxy.py -3] AP: ArduPilot Ready
  [mavproxy.py -3] AP: AHRS: DCM active
  [micro_ros_agent-1] [1733332524.264890] info     | ProxyClient.cpp    | create_participant       | participant created    | client_key: 0xAAAABBBB, participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265068] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x000(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265094] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x000(3), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265184] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x000(5), publisher_id: 0x000(3)
  [micro_ros_agent-1] [1733332524.265255] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x001(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265263] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x001(3), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265329] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x001(5), publisher_id: 0x001(3)
  [micro_ros_agent-1] [1733332524.265403] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x002(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265413] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x002(3), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265462] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x002(5), publisher_id: 0x002(3)
  [micro_ros_agent-1] [1733332524.265493] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x003(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265502] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x003(3), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265552] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x003(5), publisher_id: 0x003(3)
  [micro_ros_agent-1] [1733332524.265598] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x004(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265605] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x004(3), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265658] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x004(5), publisher_id: 0x004(3)
  [micro_ros_agent-1] [1733332524.265690] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x005(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265700] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x005(3), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265753] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x005(5), publisher_id: 0x005(3)
  [micro_ros_agent-1] [1733332524.265784] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x006(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265793] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x006(3), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265848] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x006(5), publisher_id: 0x006(3)
  [micro_ros_agent-1] [1733332524.265888] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x007(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265897] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x007(3), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.265958] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x007(5), publisher_id: 0x007(3)
  [micro_ros_agent-1] [1733332524.266005] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x008(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.266026] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0xAAAABBBB, subscriber_id: 0x008(4), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.266104] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0xAAAABBBB, datareader_id: 0x008(6), subscriber_id: 0x008(4)
  [micro_ros_agent-1] [1733332524.266186] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x009(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.266200] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0xAAAABBBB, subscriber_id: 0x009(4), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.266267] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0xAAAABBBB, datareader_id: 0x009(6), subscriber_id: 0x009(4)
  [micro_ros_agent-1] [1733332524.266335] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x00A(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.266345] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0xAAAABBBB, subscriber_id: 0x00A(4), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.266419] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0xAAAABBBB, datareader_id: 0x00A(6), subscriber_id: 0x00A(4)
  [micro_ros_agent-1] [1733332524.266481] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x00B(2), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.266491] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0xAAAABBBB, subscriber_id: 0x00B(4), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.266558] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0xAAAABBBB, datareader_id: 0x00B(6), subscriber_id: 0x00B(4)
  [micro_ros_agent-1] [1733332524.266763] info     | ProxyClient.cpp    | create_replier           | replier created        | client_key: 0xAAAABBBB, requester_id: 0x000(7), participant_id: 0x001(1)
  [micro_ros_agent-1] [1733332524.267248] info     | ProxyClient.cpp    | create_replier           | replier created        | client_key: 0xAAAABBBB, requester_id: 0x001(7), participant_id: 0x001(1)
  [mavproxy.py -3] AP: DDS: Init complete
  [mavproxy.py -3] AP: DDS: Topic/Sub/Reader session pass for index '8'
  [mavproxy.py -3] AP: DDS: Topic/Sub/Reader session pass for index '9'
  [mavproxy.py -3] AP: DDS: Topic/Sub/Reader session pass for index '10'
  [mavproxy.py -3] AP: DDS: Topic/Sub/Reader session pass for index '11'
  [mavproxy.py -3] AP: DDS: Service/Replier session pass for index '0'
  [mavproxy.py -3] AP: DDS: Service/Replier session pass for index '1'
  [mavproxy.py -3] AP: DDS: Initialization passed
  [mavproxy.py -3] AP: RC7: SaveWaypoint LOW
  [micro_ros_agent-1] terminate called after throwing an instance of 'eprosima::fastcdr::exception::NotEnoughMemoryException'
  [micro_ros_agent-1]   what():  Not enough memory in the buffer stream
  [ERROR] [micro_ros_agent-1]: process has died [pid 62312, exit code -6, cmd '/home/mscroboticslaptop19/ros2_ws/install/micro_ros_agent/lib/micro_ros_agent/micro_ros_agent udp4 --middleware dds --verbose 4 --port 2019 --refs /home/mscroboticslaptop19/ros2_ws/install/ardupilot_sitl/share/ardupilot_sitl/config/dds_xrce_profile.xml --ros-args -r __node:=micro_ros_agent -r __ns:=/'].
  [mavproxy.py -3] AP: EKF3 IMU0 initialised
  [mavproxy.py -3] AP: EKF3 IMU1 initialised
  [mavproxy.py -3] AP: AHRS: EKF3 active
  [mavproxy.py -3] AP: DDS: No ping response, disconnecting
  [mavproxy.py -3] Received 1397 parameters
  [mavproxy.py -3] AP: EKF3 IMU1 tilt alignment complete
  [mavproxy.py -3] AP: EKF3 IMU0 tilt alignment complete
  [mavproxy.py -3] AP: EKF3 IMU1 MAG0 initial yaw alignment complete
  [mavproxy.py -3] AP: EKF3 IMU0 MAG0 initial yaw alignment complete
  [mavproxy.py -3] AP: GPS 1: detected as u-blox at 230400 baud
  ^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
  [ERROR] [dds_udp.parm --synthetic-clock -2]: process has died [pid 62314, exit code -2, cmd 'arducopter --model quad --speedup 1 --slave 0 --sim-address=127.0.0.1 --instance 0 --defaults /home/mscroboticslaptop19/ros2_ws/install/ardupilot_sitl/share/ardupilot_sitl/config/default_params/copter.parm,/home/mscroboticslaptop19/ros2_ws/install/ardupilot_sitl/share/ardupilot_sitl/config/default_params/dds_udp.parm --synthetic-clock '].
  [mavproxy.py -3] Unloading module link
  [mavproxy.py -3] Unloading module log
  [mavproxy.py -3] Unloading module signing
  [mavproxy.py -3] Unloading module wp
  [mavproxy.py -3] Unloading module rally
  [mavproxy.py -3] Unloading module fence
  [mavproxy.py -3] Unloading module ftp
  [mavproxy.py -3] Unloading module param
  [mavproxy.py -3] Unloading module relay
  [mavproxy.py -3] Unloading module tuneopt
  [mavproxy.py -3] Unloading module arm
  [mavproxy.py -3] Unloading module mode
  [mavproxy.py -3] Unloading module calibration
  [mavproxy.py -3] Unloading module rc
  [mavproxy.py -3] Unloading module auxopt
  [mavproxy.py -3] Unloading module misc
  [mavproxy.py -3] Unloading module cmdlong
  [mavproxy.py -3] Unloading module battery
  [mavproxy.py -3] Unloading module terrain
  [mavproxy.py -3] Unloading module output
  [mavproxy.py -3] Unloading module adsb
  [mavproxy.py -3] Unloading module layout
The error message related to DDS is
I checked ROS_DOMAIN_ID and ROS_LOCALHOST_ONLY, and they are set to be 0.
I checked post ROS2 with SITL not working and ROS2 SITL with Gazebo not working
Now check if it works with ArduCopter 4.6.0-beta1
Hi @amilcarlucas , thanks for your reply.
Before I try ArduCopter 4.6.0-beta1, I would like to share you with my updates with 4.5.7.
After reinstalling everything. I got not error after launching it, but still no ros2 node or topic is published:
[INFO] [launch]: All log files can be found below /home/mscroboticslaptop19/.ros/log/2024-12-04-18-02-42-615837-HP-EliteBook-640-14-inch-G9-Notebook-PC-89995
namespace:
transport:        udp4
middleware:       dds
verbose:          4
discovery:        7400
port:             2019
command:          arducopter
model:            quad
speedup:          1
slave:            0
instance:         0
console:          False
map:              False
[INFO] [micro_ros_agent-1]: process started with pid [89996]
[INFO] [dds_udp.parm --synthetic-clock -2]: process started with pid [89998]
[INFO] [mavproxy.py -3]: process started with pid [90000]
[micro_ros_agent-1] [1733335362.651695] info     | UDPv4AgentLinux.cpp | init                     | running...             | port: 2019
[micro_ros_agent-1] [1733335362.652581] info     | Root.cpp           | set_verbose_level        | logger setup           | verbose_level: 4
[micro_ros_agent-1] [1733335365.101911] info     | Root.cpp           | create_client            | create                 | client_key: 0xAAAABBBB, session_id: 0x81
[micro_ros_agent-1] [1733335365.101953] info     | SessionManager.hpp | establish_session        | session established    | client_key: 0xAAAABBBB, address: 127.0.0.1:59110
[micro_ros_agent-1] [1733335365.109657] info     | ProxyClient.cpp    | create_participant       | participant created    | client_key: 0xAAAABBBB, participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.109856] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x000(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.109887] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x000(3), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110015] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x000(5), publisher_id: 0x000(3)
[micro_ros_agent-1] [1733335365.110084] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x001(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110096] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x001(3), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110188] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x001(5), publisher_id: 0x001(3)
[micro_ros_agent-1] [1733335365.110232] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x002(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110247] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x002(3), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110327] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x002(5), publisher_id: 0x002(3)
[micro_ros_agent-1] [1733335365.110384] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x003(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110401] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x003(3), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110480] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x003(5), publisher_id: 0x003(3)
[micro_ros_agent-1] [1733335365.110525] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x004(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110550] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x004(3), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110631] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x004(5), publisher_id: 0x004(3)
[micro_ros_agent-1] [1733335365.110676] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x005(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110686] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x005(3), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110771] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x005(5), publisher_id: 0x005(3)
[micro_ros_agent-1] [1733335365.110815] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x006(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110830] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x006(3), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110908] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x006(5), publisher_id: 0x006(3)
[micro_ros_agent-1] [1733335365.110970] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x007(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.110980] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0xAAAABBBB, publisher_id: 0x007(3), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.111082] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0xAAAABBBB, datawriter_id: 0x007(5), publisher_id: 0x007(3)
[micro_ros_agent-1] [1733335365.111136] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x008(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.111162] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0xAAAABBBB, subscriber_id: 0x008(4), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.111277] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0xAAAABBBB, datareader_id: 0x008(6), subscriber_id: 0x008(4)
[micro_ros_agent-1] [1733335365.111453] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x009(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.111500] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0xAAAABBBB, subscriber_id: 0x009(4), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.111760] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0xAAAABBBB, datareader_id: 0x009(6), subscriber_id: 0x009(4)
[micro_ros_agent-1] [1733335365.112041] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x00A(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.112084] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0xAAAABBBB, subscriber_id: 0x00A(4), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.112271] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0xAAAABBBB, datareader_id: 0x00A(6), subscriber_id: 0x00A(4)
[micro_ros_agent-1] [1733335365.112445] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0xAAAABBBB, topic_id: 0x00B(2), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.112491] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0xAAAABBBB, subscriber_id: 0x00B(4), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.112680] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0xAAAABBBB, datareader_id: 0x00B(6), subscriber_id: 0x00B(4)
[micro_ros_agent-1] [1733335365.113345] info     | ProxyClient.cpp    | create_replier           | replier created        | client_key: 0xAAAABBBB, requester_id: 0x000(7), participant_id: 0x001(1)
[micro_ros_agent-1] [1733335365.113946] info     | ProxyClient.cpp    | create_replier           | replier created        | client_key: 0xAAAABBBB, requester_id: 0x001(7), participant_id: 0x001(1)
[mavproxy.py -3]
[mavproxy.py -3] AP: DDS: Topic/Pub/Writer session pass for index '5'
[mavproxy.py -3] AP: DDS: Topic/Pub/Writer session pass for index '6'
[mavproxy.py -3] AP: DDS: Topic/Pub/Writer session pass for index '7'
[mavproxy.py -3] fence present
[mavproxy.py -3] Flight battery 100 percent
[mavproxy.py -3] AP: EKF3 IMU1 origin set
[mavproxy.py -3] AP: Field Elevation Set: 584m
[mavproxy.py -3] AP: EKF3 IMU0 origin set
By the way, even I fetch the last version of ardupilot, I cannot find any branch or tag whose name is Copter-4.6.0-beta1.
Could you please tell me where to get it?
It would be Ardupilot-4.6.0-beta1. If you haven’t pulled the repo recently (in the last 2 weeks), you have to pull before, to make sure the branch exists on your machine.
Thanks for your reply. Let me have a try.
solved: it is because I changed fastDDS to another DDS and it seems to be the reason. It works after I switch back to fastDDS.
