I am controlling a copter with ROS2 humble and I would like to ask how to send thrust + attitude cmd in guided and guided_noGPS modes.
I followed guides on Ardupilot webstite and SITM can run with ROS2 humble. However, ROS 2 Interfaces shows only ap/joy, ap/cmd_vel and ap/cmd_gps_pose are provided.
Unfortunately, it seems like none of them can enable me to send thrust + attitude commands. But I believe it should be possible, as there is already a function void AC_AttitudeControl::input_thrust_vector_heading(const Vector3f& thrust_vector, float heading_angle_cd, float heading_rate_cds), which is defined in ardupilot/libraries/AC_AttitudeControl /AC_AttitudeControl_Multi.cpp.
I think RyanF is probably best place to help here.
One thing I can add is we have the GUID_OPTIONS parameter that affects how mavlink SET_ATTITUDE_TARGET messages are interpreted (it changes whether the “thrust” field is interpreted as thrust or climb-rate. This may be unrelated though.
Thanks for the input. This isn’t yet supported. Please create an issue on Github, tag me me with the request (ryanf55) on Github, and we can work out a message definition suitable for the application. Once we have a suitable message chosen, it would be much appreciated if you wanted to contribute a feature for it.
Hi @robin_drone ! So individual Motor Control works fine and is complete. Here’s the PR:
For attitude and thrust control, I started it out but yet to complete. I’ll try to complete it this week. In any case, if you want to use direct motor control, feel free to use my PR.
Hi @robin_drone ! So the thrust and attitude code is done but there are changes to be done to XRCE c codegen. I did not get time to work on the codegen part. I’ll complete that over this weekend.
@snktshrma Hey, I had some doubts regarding how your code works. Is your code specifically for external controllers other than the autopilot board running ArduCopter?
Also, how does one control the thruster PWM of the ArduCopter board, say a Pixhawk 4, within a ROS 2 network?
@snktshrma ,Could you please briefly introduce how DDS of ROS2 communicate with ArduCopter in the source code?
Because I really want to contribute to ROS2-ArduCopter as well. Unfortunately, I have found little information about how it is implemented in the source code of ArduCopter.
It would be definitely helpful to me if you can explain this a little.
Hi @robin_drone ! As @rmackay9 sir suggested, look at the docs and also at readme at AP_DDS library on github. Also have a look at and skim through some of these PRs. They’ll give you a sense of how various function in main AP code are modified/called and used by AP_DDS library.
I’ve read the documentation, and it’s very helpful from a user’s perspective. However, I’m interested in contributing to the project, and I’ve found that there’s limited guidance on how to get started as a contributor.
For example, it’s unclear how the communication between DDS and ArduPilot is implemented. Understanding this would be important for making meaningful contributions.
At the moment, it takes considerable time to navigate the source code and identify an appropriate entry point. Any additional documentation or guidance for contributors would be greatly appreciated.
