Here’s the output. The first “Got new packet” line is without a GCS application connected. The second one corresponds to the same error in Mission planner I posted earlier, when that error is thrown.
Checking for new packet at 2023-06-23, 13:44:45
Checking for GCS packets
Sleeping 2
Checking for new packet at 2023-06-23, 13:44:49
Got new packet, coords 28.019,-81.749. Received at 2023-06-23 13:44:41 UTC
HIGH_LATENCY2 {timestamp : 481688, type : 2, autopilot : 3, custom_mode : 0, latitude : 0, longitude : 0, altitude : 0, target_altitude : 0, heading : 168, target_heading : 0, target_distance : 0, throttle : 0, airspeed : 0, airspeed_sp : 0, groundspeed : 0, windspeed : 0, wind_heading : 0, eph : 0, epv : 0, temperature_air : 35, climb_rate : 0, battery : 99, wp_num : 0, failure_flags : 65, custom0 : 1, custom1 : 0, custom2 : 0}
Sleeping 2
Checking for new packet at 2023-06-23, 13:44:53
Sleeping 2
Checking for new packet at 2023-06-23, 13:44:58
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:02
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:05
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:08
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:11
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:14
Got new packet, coords 28.0023,-81.7548. Received at 2023-06-23 13:45:05 UTC
HIGH_LATENCY2 {timestamp : 501789, type : 2, autopilot : 3, custom_mode : 0, latitude : 0, longitude : 0, altitude : 0, target_altitude : 0, heading : 168, target_heading : 0, target_distance : 0, throttle : 0, airspeed : 0, airspeed_sp : 0, groundspeed : 0, windspeed : 0, wind_heading : 0, eph : 0, epv : 0, temperature_air : 35, climb_rate : 0, battery : 99, wp_num : 0, failure_flags : 65, custom0 : 1, custom1 : 0, custom2 : 0}
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:18
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:21
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:24
Sleeping 2
Checking for new packet at 2023-06-23, 13:45:27
Got new packet, coords 28.019,-81.749. Received at 2023-06-23 13:45:22 UTC
HIGH_LATENCY2 {timestamp : 521794, type : 2, autopilot : 3, custom_mode : 0, latitude : 0, longitude : 0, altitude : 0, target_altitude : 0, heading : 168, target_heading : 0, target_distance : 0, throttle : 0, airspeed : 0, airspeed_sp : 0, groundspeed : 0, windspeed : 0, wind_heading : 0, eph : 0, epv : 0, temperature_air : 35, climb_rate : 0, battery : 99, wp_num : 0, failure_flags : 65, custom0 : 1, custom1 : 0, custom2 : 0}
Traceback (most recent call last):
File "C:\Users\Kevin\Desktop\rockblock2mav_debug\rockblock2mav\rockblock2mav.py", line 136, in <module>
data, addr = UDPClientSocket.recvfrom(UDP_MAX_PACKET_LEN)
ConnectionResetError: [WinError 10054] An existing connection was forcibly closed by the remote host
