I will do this but they are very slow to respond, when they do not all the customer service agents are knowledgeable. Thank you for your help
Is there a solder pad on the other side of it?
No nothing. The other side is the lid of the surround
Purchased, delivered and installed with no issues. Great suggestion.
Any enhanced parameter suggestions or just leave as is?
Thank you
Should be good. It’s an AP_Peripheral device so I believe you could connect a serial GPS to it if you wanted to. No advantage really unless you needed another serial port.
You made me think of a new idea. I will add a GPS serial port to connect it to CAN in the next iteration on our module.
