I have issues in connecting the rdf900x radio as relay (forwarding) with asynchronous firmware v2.47. My setup is:
Node 1: ATS10 = 1, ATS11 =3 // set node 1, destination 3
Node 3: ATS10 = 3, ATS11 =1 // set node 3, destination 1
Node 2: ATS10 = 2, ATS11 =don’t care (4), AT+F0=1,3, AT+F1=3,1 // forward 1->3, and 3->1
All set to Net 25
After setting up, my flight GCS laptop mission planner rfd900x (node 1) binds with aircraft rfd900x (node 3) directly, the in between node2 rfd900x doesn’t seem to power up at all, no lights whether i use a 5v power supply or plug into laptop USB port. So the data is not relayed via node 2. Node 2 rfd900x can be programmed so i know its physically working.
Yes, They sent me a spreadsheet for using multipoint binary for relay aircraft.
The latest multipoint binary is attached.
Note s parameter index may be different for this version.
use ATI5 to check correct s parameter index.
I can’t upload the files here, not correct format. What’s your email?
Hello, sorry for old topic posting)
Did you solve your forwarding problems with 900x? A have a pretty similar question.
I have an issue in connecting the rdf900x radio as a relay with asynchronous firmware.
I have made the setup in the following way (i used RFD900x Asynchronous firmware User Manual with 09/07/2018 update)
I use RFD900x-AsyncRelease_V2.64 firmware.
Node 2: ATS10 = 2, ATS11 =don’t care, AT+F0=1,3, AT+F1=3,1 // forward 1->3, and 3->1
after setting up , my flight controller rfd900x (node 1) get binds with gcs rfd900x (node 3) in between i just powered on node2 rfd900x. Seems to be the data is not relayed via node 2.
Are there any recommended ways to solve it?
PS/ I tried to set Node1 ATS11(destID)=32768 and Node3 ATS11=32768. It looks like in this case, Node2 is working as a relay, but this option increases data losses. Are there any recommend ways?
