Haa, thanks for answering, yes I’ve tried everything, even discussing with the devs, compiling special firmwares etc…
But it’s good to know it should work, maybe I have a hardware issue.
Are you under EdgeTx or Opentx ? And if you happen to know which FW version you’re on that would be great.
Thanks again
The TX16S was on OpenTX and recently upgraded to EdgeTX - no change in operation as far as the TXMOD is concerned. The models and all transferred over without modification.
Just for additionnal info if anyone faces this issue.
After contacting RFDesign, they told me that it’s a known issue with the TXMod v1 which was fixed with the v2.
They blamed radiomaster for not outputting enough voltage on the external pin, which is weird because 6 years old dragonlink can handle it.
Anyway they offer to purchase a whole new v2 kit with the modem when it’s only a mod on the housing of the modem.
