RFD 900x / 868x frequency
Can you remove the radio from the aircraft and connect it directly to a computer to determine and set the NetID? Apart from guessing that’s the only way you will find the NetID
Or I guess you are still trying to the one to many thing…
If you know the NetIDs of all the airborne radios, then you could keep changing the NetID of the ground radio to communicate with the different aircraft - but that gives you a substantial black-out period for each aircraft.
My work is to scan the transmitter telemetry module netid’s continuously and whenever it matches with the receive module netid then both should be paired and mavlink data need to be received.
Hiiii
I also wanted to know, when any binary data (only 0’s and 1’s will be there)is given I need to retrieve the NetID, Number of channels, Min_Frequency, Max_Frequency, Air Data rate, ECC, MaxWindow of the RFD900 telemetry radio module. Any procedure is there for the above mentioned query?
  1. RFD does that on its own
  2. NetID and other parameters can be obtained and changed using AT commands as described in the documentation.
We are a UAV Team at Istanbul Technical University. Our team has been using your RFD900x modules for many years and we were getting very good results. Our competition range is approximately 1km, and until last year, the RFD health value never dropped below 90%. This year, however, after moving a few hundred meters, this value drops to 50%, and in some cases, it even causes disconnections. The RFD position inside the aircraft has not changed compared to last year. Some RFDs had a different firmware, such as MultiComm, installed for a while, but then reverted to the SiK 3.57 firmware (MultiComm was used as PtMP). Currently, all aircraft are using 3.57 firmware. It is possible that 2.4 GHz or 5.8 GHz antennas were accidentally used on the RFDs. We suspect that this may have caused permanent damage to the RFDs. We are sending this email to ask for your advice and to find out the reason for this. Is there any way to find out the reason or test it in any way? Is there a way to compare our current RFDs against any brand new product on RFDesign? Can you suggest a parameter or test method we could use?
If you put the correct antennas on the radios should operate normally. It’s quite difficult to damage the RFD radios, and I know many have been operated without antennas at all for quite a long time and not suffered damage.
There could even be something else on the UAV that has started causing interference.
