Yesterday I flew my foam-board airplane that I’m using to learn ArduPlane - it was it’s second flight.
It wasn’t a long flight - as it was too late in the day. But after taking off in FBWA mode I was able to successfully test automated flight by switching to LOITER.
As I’m unfamiliar with many aspects of “plane” - I would really appreciate anyone’s help by taking a look at this BIN file and suggesting changes as necessary to the parameters.
I’m logging before arming - so the log covers everything from power up to power down.
As this plane is scratch built, I’m curious to know how much the autopilot might be correcting for CG placement. It’s a Clark-Y airfoil that I’ve set CG at about 28%.
The wing has no dihedral - but FBWA mode keeps the airplane perfectly stable in straight and level flight - and turns. The only issue I’ve noticed is that I need to learn how to descend for landing. The plane required a couple of 360 turns to get low enough to attempt a landing. Turns out my wing is a lot more efficient than I’d expect.
One outstanding issue is that the CubePilot Mini Power Brick is not able to register the low amperages of this plane - even after proper calibration. I’ve ordered a MAUCH PL-050 which should be much better. If anyone has any other suggestions, I’d appreciate them.
Thank for your help!
