you might be able to get it to work as it is, would be a bit of a bodge tho. I think negative pitch PID gains would make a ‘revese tricopter’ work and you might be able to get the the tilt working with the tilt output, however I think you would need a new class to get only yaw with the rear tilts and use the front for transition.
Great idea,
we will first look how the plane will behave as a copter. The wiring is done/planned as follows:
Motor 1 output with rear Motor right (instead of right frontmotor as usual)
Motor 2 output with rear motor left (instead of left frontmotor )
Motor 4 output with front motor (instead of the rear mtoor)
Q_TILT_MASK = 8 (only Motor 4 is tiltable)
Q_TILT_TYPE = 0 (no vectored for der Controler)
ServoXX_Function 41 to the front motor tilt servo
Motor 7 Output (usualy for yawservo) with both ±30° tiltservos of the rear motors.
Might even work right out of the box if your lucky, if I get a chance I will add a reverse tricopter mixer. With those settings I don’t think you will need anything custom on the tilt rotor side.
I think a new Q_FRAME_TYPE makes sense for this. I think we’ll also need some work in the ArduPlane/tiltrotor.cpp code, as we’d need to support vehicles where some motors only tilt by a small amount and others tilt a large amount.
Until then we will first test with the negative P-values for pitch. We hope to be able to make the first hoverings at the end of April.
Rolf
I have done a PR for reversed tricopter, should make it into master before you need it hopfully, otherwise I can build it for you.
This just inverts the outputs of the PID’s so is the same as using negative PID’s but now you wont get the errors and you can autotune. You need to set Q_FRAME_TYPE to 6 for MOTOR_FRAME_TYPE_PLUSREV.
Thanks a million Peter
The fuselage and the tilt mechanism is completed. I’m still waiting for the delivery of the ESCs.
As soon as the ESCs will arrive, we want to perforn the first hover tests (still without wings. The wings still under construction are outlined in yellow)
@iampete Peter, could you build us a binary for a pixhawk 1?
So we do not need to use negative PIDs and will set Q_FRAME_TYPE to 6 for MOTOR_FRAME_TYPE_PLUSREV
Happy Easter
Best Regards
Rolf
Next week fits, because I still have to solder everything. Thank you in advance.
arduplane.apj (910.5 KB)
I have re-based on master, just set Q_FRAME_TYPE to 6 for MOTOR_FRAME_TYPE_PLUSREV
Thanks a million Peter, just in time
Everything is soldered and just connected the battery for the first time. No smoke signals
![:grinning: :grinning:](https://discuss.ardupilot.org/images/emoji/twitter/grinning.png?v=9)
Tomorrow I want to install the firmware.
Rolf
yep, looks good.
The two rear motor tilt outputs would be M7
yep. I hope it doesn’t matter that it’s nominally a motor output because I switched the motor outputs to Dshot. If not, I have to switch the motorutputs to PWM.
For the first hover-tests we have vectored yaw enabled - with a little trick:
Our rear servo mechanics tilts the motors at PWM values between 1100µs and 1900µs by +/- 45°. The rear servos of course can not tilt the engine completely forward, but the software does not know. You simply have to set SERVOn_MIN down to a suitable “virtual” value, as in the following example:
On the bench it works (QSTABILIZE):
Unfortunately, in one of the tests, a mechanical failure caused the front servo to break. Better on the ground than later in the air. It will take a few days until a new servo is installed.
The servo problem is almost resolved, but the weather is too bad for test flights. @Walter used the bad weather to finish the wings.
After repair of the servomechanics we wanted to complete the first hoverfly in qstabilize today.
Unfortunately, the pitch regulation goes in the wrong direction. The aircraft would therefore jump over immediately after taking off. AHRS_ORIENTATION is 0, Pixhawk shows forward, Q_FRAME_TYPE is 6, Q_FRAME_CLASS is 7. PIDs are positiv. (Roll is okay).
Here is the full parameterlist:
mozart2.param (20.8 KB)
Rolf
hum, thats strange, do you have a log?
Yes, just tried again due to the rainy weather indoor :
https://www.magentacloud.de/lnk/Evginj7b
I turned the plane by hand alternately forward and backward or to the sides.
Roll works properly, Nick stops the front engine when the nose is down (instead up)
Motor 1 (rear right) Servo9_Function=33
Motor 2 (rear left Servo10_Function=34
Motor 4 (Front) SERVO11_FUNCTION=36
