I’m trying to find a way to have logs after a real flight or after a SITL simulation (Arduplane). These logs will give me a sort of “retro engineering” view of what happened in term of commands.
Let me explain:
I’m doing my flight with MP
After the flight, I’ve got logs that will give me the details of what the plane have done at each second about the pitch, the throttle , the roll and the yaw in degrees : “At 30 seconds, the pitch was at x°, the roll at x° and the yaw at x° and the throttle at x%”
=> The goal is to help me building a python script based on a “perfect” flight, because it’s really difficult to write an efficient and realistic script before the flight if this flight is very complex and with a high duration. And it’ll help me understand clearly the flight mecanisms of my plane !
I don’t know if it’s possible, your help and any tips are welcome !
Of course it is possible. Just load a dataflash log after the flight, using the mavexplorer code as inspiration on how to read and decide the .bin files.
Hi Amilcarlucas, coming back to you with this old post.My goal is to make some reverse engineering based on a virtual flight with MP + logs or a real flight + logs. I want to go from any logs => Python or LUA code. I tried with analysis on a .csv file from MP logs, but the amount of attitude data is really huge and I didn’t find the way to go from these attitude data to Python/LUA script. Working on this for months now and didn’t find the right solution, the goal is to “mimic” an acrobatic flight made manually with a RC pilot or with MP+SITL+joystick and reproduce this flight in a “UAV - automatic” flight in Arduplane.
Manual/Virtual flight => Arduplane automatic flight
I hope it’s clear, if you have any idea you’re really welcome !
Thanks
Nico
Thanks for your answer, I’ve reached Matlab people for a trial test, seems really hard to work with their internal code . But this project for logs looks really cool, I’ll check it deeply.
Bye
Nico
