Hi everyone,
I have FLOC retracts attached to my Iris. It works good on stable firmware, 3.2.1, but not on 3.3. I’ve tested both firmwares with the same parameters file (see attached file). I have connected the gears servo to Aux, set a function for the Aux port and then set the relevant Relay_Pin number for the port. I know there should now be support for retracts in 3.3, but I have not yet succeeded to get that to work and there is very little info about it. Is it a bug in 3.3 that “the old way” is not working? How do I get retracts to work in 3.3?
Thank you for any help,
