Hi all
Is there a known bug in the Resume function of the iOS version of GGC? When i pause my mission mid air, RTL, land, change battery (while leaving the controller and QGC connected), the mission always resumes from point 1 and not the paused/abort point.
The only thing i do differently to the instructions is that i do a manual take off using the controller instead of simply using the resume mission slider (I do this as i have found using the take off function / start mission function of QGC causes my copter to topple over on the ground while trying to take off!!!).
Any help or advice will be appreciated, thanks
Rory
