Does anybody have any issue with Speedybee F405Wing FC logging?
Running Plane 4.4.0 and everything seems fine. VTOL aircraft flies ok. Set LOG_BACKEND_TYPE=4 and INS_LOG_BAT_MASK=1, nothing gets logged to dataflash memory. So I put in a microSD card and changed LOG_BACKEND_TYPE=1, still no logs.
Wanted to see if this is a common problem, or did I missed something?
I am stumped. Tried 4 different SD cards on 2 different Speedybee F405Wing, one running 4.4.0 stable and one running 4.5.0 dev. The one on 4.5.0 writes an empty file, while the 4.4.0 just doesn’t write anything.
Looks like the issue IS MicroSD incompatibility. Dug up an old 8GB MicroSD and formatted with FAT32. The FC is able to write logs to it. Guess it didn’t like my 32GB cards.
@steph280 I am also having same issue and most likely SD card related; however, if the logging was not taking place, how did you able to arm the plane?
All my other FC (pixhawk, Matek), they will not arm if logging is failing or atleast I get a message logging fail.
Do you think its a bug?
What were your final parameters? Any changes to logging_Bitmask?
