I am using an Arduino as a companion computer to read the messages from a Pixhawk using MAVLINK. I am successfully able to read all data streams by setting “MAV_DATA_STREAM_ALL”. Now, I have a condition where I need to get the system Unix time since epoch and GPS coordinates as and when I send a request from the Arduino companion and not continuously.
I am very new to this (started working on a DIY project from last 3 days) and I am unable to find any reference or code snippets to do this task. Can anyone here help me out?
This is my code to read all the stream data and extract what I need.
But I want to implement a system where I can request example Message ID 22 (MAVLINK_MSG_ID_SYSTEM_TIME) and get the response from pixhawk for that.
#include "common/mavlink.h"
//#include "common/mavlink_msg_request_data_stream.h"
// Mavlink variables
unsigned long previousMillisMAVLink = 0; // will store last time MAVLink was transmitted and listened
unsigned long next_interval_MAVLink = 1000; // next interval to count
const int num_hbs = 60; // # of heartbeats to wait before activating STREAMS from Pixhawk. 60 = one minute.
int num_hbs_pasados = num_hbs;
// MAVLink
/* The default UART header for your MCU */
int sysid = 1; ///< ID 20 for this airplane. 1 PX, 255 ground station
int compid = 158; ///< The component sending the message
int type = MAV_TYPE_QUADROTOR; ///< This system is an airplane / fixed wing
// Define the system type, in this case an airplane -> on-board controller
// uint8_t system_type = MAV_TYPE_FIXED_WING;
uint8_t system_type = MAV_TYPE_GENERIC;
uint8_t autopilot_type = MAV_AUTOPILOT_INVALID;
uint8_t system_mode = MAV_MODE_PREFLIGHT; ///< Booting up
uint32_t custom_mode = 0; ///< Custom mode, can be defined by user/adopter
uint8_t system_state = MAV_STATE_STANDBY; ///< System ready for flight
void setup()
// MAVLink interface start
Serial2.begin(57600);
Serial.begin(57600);
Serial.println("MAVLink Companion starting.");
void loop()
// Initialize the required buffers
mavlink_message_t msg;
uint8_t buf[MAVLINK_MAX_PACKET_LEN];
// Pack the message
//mavlink_msg_heartbeat_pack(sysid,compid, &msg, type, autopilot_type, system_mode, custom_mode, system_state);
mavlink_msg_heartbeat_pack(1, 0, &msg, type, autopilot_type, system_mode, custom_mode, system_state);
// Copy the message to the send buffer
uint16_t len = mavlink_msg_to_send_buffer(buf, &msg);
// Send the message with the standard UART send function
// uart0_send might be named differently depending on
// the individual microcontroller / library in use.
unsigned long currentMillisMAVLink = millis();
if (currentMillisMAVLink - previousMillisMAVLink >= next_interval_MAVLink)
// Guardamos la última vez que se cambió el modo
previousMillisMAVLink = currentMillisMAVLink;
Serial2.write(buf, len);
//Mav_Request_Data();
num_hbs_pasados++;
if (num_hbs_pasados >= num_hbs)
// Request streams from Pixhawk
Serial.println("Streams requested!");
Mav_Request_Data();
num_hbs_pasados = 0;
// Check reception buffer
comm_receive();
void Mav_Request_Data()
// STREAMS that can be requested
Definitions are in common.h: enum MAV_DATA_STREAM
MAV_DATA_STREAM_ALL=0, // Enable all data streams
MAV_DATA_STREAM_RAW_SENSORS=1, /* Enable IMU_RAW, GPS_RAW, GPS_STATUS packets.
MAV_DATA_STREAM_EXTENDED_STATUS=2, /* Enable GPS_STATUS, CONTROL_STATUS, AUX_STATUS
MAV_DATA_STREAM_RC_CHANNELS=3, /* Enable RC_CHANNELS_SCALED, RC_CHANNELS_RAW, SERVO_OUTPUT_RAW
MAV_DATA_STREAM_RAW_CONTROLLER=4, /* Enable ATTITUDE_CONTROLLER_OUTPUT, POSITION_CONTROLLER_OUTPUT, NAV_CONTROLLER_OUTPUT.
MAV_DATA_STREAM_POSITION=6, /* Enable LOCAL_POSITION, GLOBAL_POSITION/GLOBAL_POSITION_INT messages.
MAV_DATA_STREAM_EXTRA1=10, /* Dependent on the autopilot
MAV_DATA_STREAM_EXTRA2=11, /* Dependent on the autopilot
MAV_DATA_STREAM_EXTRA3=12, /* Dependent on the autopilot
MAV_DATA_STREAM_ENUM_END=13,
// To be setup according to the needed information to be requested from the Pixhawk
const int maxStreams = 1;
const uint8_t MAVStreams[maxStreams] = {MAV_DATA_STREAM_ALL};
const uint16_t MAVRates[maxStreams] = {0x01};
const int maxStreams = 2;
const uint8_t MAVStreams[maxStreams] = {MAV_DATA_STREAM_EXTENDED_STATUS, MAV_DATA_STREAM_RAW_SENSORS};
const uint16_t MAVRates[maxStreams] = {0x01, 0x01};
for (int i = 0; i < maxStreams; i++) {
mavlink_msg_request_data_stream_pack(system_id, component_id,
&msg,
target_system, target_component,
MAV_DATA_STREAM_POSITION, 10000000, 1);
mavlink_msg_request_data_stream_pack(uint8_t system_id, uint8_t component_id,
mavlink_message_t* msg,
uint8_t target_system, uint8_t target_component, uint8_t req_stream_id,
uint16_t req_message_rate, uint8_t start_stop)
mavlink_msg_request_data_stream_pack(2, 200, &msg, 1, 0, MAVStreams[i], MAVRates[i], 1);
