I have several V2450GPS drones I purchased as a lot. They were returns from retail stores. I would like to use the hardware from a V2450GPS drone to control a ground based device that uses hoverboard motors for positioning. All the capabilities I need come with the drone so I thought maybe I could load ROVER and make hardware modifications to interface the motors.
I’m just trying to think it through right now and my first question is:
Is there a better way to go about this? i.e. Is there an off the shelf device using open source Rover similar to what SkyRocket provided for the drones that I should start with instead of re-inventing the wheel?
Thank you in advance for any advice, knowledge or directions you may have to get me started.
Best regards,
Ken
