I have a 450 size heli with a shaft driven variable pitch tail rotor, does
APM have an option for helicopters with using a brushless ESC in
combination with variable pitch tail rotors? Or just a brushless ESC
with a fixed pitch tail rotor?
For DDVP, the ESC must be running in governor mode. For DDFP, the ESC must be in normal mode, and obviously should be a high-response type, similar to a multirotor.
That type of question is outside the scope of this forum, but I’ll try to answer.
Generally, any ESC intended for helicopters will have a governor function, and you’d have to read it’s manual to find out how to use it. It usually requires a programming card.
I can recommend the Hobbyking YEP, K-Force, and Superbrain ESC’s.
The Hobbywing Platinum ESC’s should also be good, but I haven’t used them yet. But Hobbywing IMO are the most reliable low-cost ESC’s on the market. The K-Force ESC’s are rebranded HW’s.
