When I try to connect mission planner to 3DR solo, I find that the parameter fetch is taking a long time most of the times. When I looked at the parameters it is fetching, I’ve observed that it is fetching the same set of parameters repeatedly in a never-ending loop. Is this a bug or is there a work around?
please provide the tlog.
the only way this can happen is a lot of packet loss. so I would look for issues on that front first.
Please find the attached logs.
https://drive.google.com/open?id=1Q0ZJZm_xe-qcNcippQLb4vBgf8wrFS03
what version of missionplanner?
1.3.53
I haven’t tested with the latest version yet (1.3.56)
Thanks,
Krishna C. G.
MSCS,
TAMU
please test the latest.
I can see how it could happen, but the latest definitely doesn’t have this issue.
the gimbal and the solo are both responding.
