Hello Everybody,
I am completely new here, and found this place by googling as I am looking for a solution for the following problem: I have bought a Garmin Echomap 62CV (incl. GT20-TM transducer) because it can send out a NMEA 0183 signal which enables me to do a bathymetric survey with Reefmaster. I had intended to use a old laptop with two serial ports.
I connected ground and Tx (transmit) from the Garmin to the respective ground and Rx of the DB9 RS422 serial port through a OPTO-4 isolator (as advised by Actisense) as per below:
The strange thing is I am not getting any signal into Reefmaster, although with Putty I can see NMEA stream is being send out (ref below)
I tried all sort of settings, different laptops and even a serial to USB adaptor but the GPS and depth sensor data is just not coming through. I cannot ask a question on the Reefmaster forum which can not be accessed due to some strange bug (please complete CAPTCHA which is not being generated)
Is there anybody who perhaps could advise me what could be the problem because I am about to throw in the towel
Thanks a lot
Michiel
Data being received:
$PGRMM,WGS 8406
$SDDBT,f,M,F28
$GPAPB,V,V,N,V,V,N68
$GPGLL,5146.9776,N,00440.1513,E,063435,A,A4F
$GPBOD,T,M,47
$GPBWC,063435,T,M,N,A7C
$GPVTG,286.45,T,284.88,M,0.00,N,0.00,K,A20
$PGRMM,WGS 8406
$SDDBT,f,M,F28
$GPGLL,5146.9776,N,00440.1513,E,063436,A,A4C
$GPBOD,T,M,47
$GPBWC,063436,T,M,N,A7F
$PGRMM,WGS 84*06
The power cable of the Garmin has the NMEA 0183 functionality build in by providing the Rx and Tx ports as follows (the NMEA 2000 signal comes straight out of the back through a separate connector) Below snapshot is from the manual
My set-up:
