Hello, i notice that video recorded during missions are at a much lower quality than when showed realtime.
I am using an UDP stream at Full HD at about 4mbit, while the image in realtime is fine the recorded video quality is much lower and looks like a 5 FPS video.
Is there anything i can do to make it better in recording quality?
regards,
Corrado
Michael, do you have any hint?
currently there was a limit put on it, as it chews cpu.
ie encoding fullhd or higher in realtime is extremely resource intensive. so the framerate was cut.
ill see if I can add a changeable limit.
I just modified the beta to record at 25hz, please try that
Is tha at an higher resolutiin too?
the resolution is at what size you have the hud
Ok, thanks, will give it a try.
Corrado
