No, should i ? They only feed +5V right ? Is that bad ?
So i did a lot of test with the “motor test function” not they are all working with the test function
First: motors are all working (when i cross the connections they do at least)
Second:
Only 1 out of 4 skywalker ESC’s are working [no idea how or when they broke?]
all 4 simonks ESC’s are working
I swapped all skywalker ESC’s back to simonks ones
But still can’t control them with the transmitter.
What does this mean? Note they are working? Not working?
As I said there is no “cross connection” it doesn’t matter how you wire them for operation, only for direction and then it’s switch any 2 to change that.
I would guess you entered configuration mode when fiddling with calibration and set something wrong. It’s easy to do with those old tech ESC’s.
This cannot be the problem man. It’s basic Brushless DC Motor operation. If this is true then how will you reverse the motor directions if required on a SimonK firmware ESC? Had you bought Modern tech BLHeli_32 ESC’s this is trivial using an application.
In that video it’s not clear how you are trying to Arm. It’s Low Throttle Right Rudder.
I don’t know what mode 1 radio is ?
My hobby shop told me to “pull the sticks to the bottom right” to arm the motors
i copied the mission planner “flight mode” settings from this video
