Hello There
I wanted to receive waypoint information to Arduino when drone reaches to that waypoint so that I could control servo the same time when it reaches to that waypoint
note: Here I am planning to plot more than 30 waypoints and I wanted that for agricultural use
These will help-
This could all be done on board with scripting, https://ardupilot.org/copter/docs/common-lua-scripts.html
this is certainly the best way, i always keep forgetting about it, need some of that scripting in my life
Isn’t there even a mission command to control a servo connected to the FC?
We are dealing with triggering of an automated event here when certain conditions met
If you must use an Arduino, I have an example of a working project: bitdog-io/restraining_bolt: Arduino software to monitor and restrain ArduPilot drones (github.com). It uses the MAVLINK library and requires too much memory for some basic Arduinos. I used a Teensy 4.1 and it works really well.
