Hello
I want to get the final altitude calculated by the autopilot via pymavlink.
By final altitude, I mean the summation of all altitudes calculated from all sensors, such as GPS, altitude sensors such as LiDAR Lite V3, and barometers in meters.
I was found “VFR_HUD” and “AHRS2” altitude but both of them in ASL and I don’t know which one is the control output that mentioned in this link.
Here is my code :
from pymavlink import mavutil
import argparse
import time
import serial
myport = 'COM6'
# myport = '/dev/ttyTHS0'
mybaudrate = 115200
# Start a connection listening on a UDP port
# the_connection = mavutil.mavlink_connection('udpin:localhost:14550')
# Start a connection listening on a USB port
the_connection = mavutil.mavlink_connection(myport,mybaudrate)
# Wait for the first heartbeat
# This sets the system and component ID of remote system for the link
the_connection.wait_heartbeat()
print("Heartbeat from system (system %u component %u)" % (the_connection.target_system, the_connection.target_component))
# Once connected, use 'the_connection' to get and send messages
# the_connection.mav.request_data_stream_send(the_connection.target_system, the_connection.target_component, mavutil.mavlink.MAV_DATA_STREAM_ALL,
# 10, # Hz
# 1, # enable
the_connection.mav.request_data_stream_send(the_connection.target_system, the_connection.target_component, mavutil.mavlink.MAV_DATA_STREAM_POSITION,
10, # Hz
1, # enable
while 1:
# msg = the_connection.recv_match(blocking=True)
print('before')
#msg = the_connection.recv_match(type='ATTITUDE', blocking=True)
#msg = the_connection.recv_match(blocking=True)
#print(msg)
msg = the_connection.recv_match(type='AHRS2', blocking=True)
# print(msg)
altitude = msg.altitude
print(altitude)
msg = the_connection.recv_match(type='VFR_HUD', blocking=True)
altitude = msg.alt
print(altitude)
msg = the_connection.recv_match(type='TERRAIN_REPORT', blocking=True)
altitude = msg.current_height
print(altitude)
# msg = the_connection.recv_match(type='CTUN', blocking=True)
# altitude = msg.Alt
# print(altitude)
print('after')
