I have a flow meter sensor that output PWM. how can I read that value from that sensor connecting to GPIO pin in Lua script?
I read this GPIO. If I set board count to less then output pins will AP read the value automatically and what I have to do is just read from the script?
Reading GPIO input from script
We cant do PWM in or GPIO with scripts currently, it would be a great feature to add.
You should be able to do it with the binding desc (on master) you would add
AP_HAL::PWMSource
userdata type and hal.gpio
function bindings. Hopefully it will just be a matter of adding to the auto generated bindings but you may need custom bindings.
Analogue in would be another one that would be very useful.
Thanks you very much. I will need to dig through to AP::HAL
then. can you give me a hint which method read input, please?
I had successfully read flow sensor with Lua script. I add a function in vehical.cpp
. the code I use from AP_BattMonitor_FuelLevel_PWM
the read
function. I just modify a little bit.
