Reading an (ADC) analog value
Hi Guys,
We are using cuav x7 Pro+ in our project. We want read analog sensor. Its voltage rate is 0-5V. There is a 2 external analog input pin in cuav. One of the analog reading range is 3.3V, another one is 6.6V.
AnalogPin
I set BATT9_MONITOR to 3. As you can see from the screenshot that i share it means ‘Analog Voltage Only’
I confused about the pin assignment. I should say to the ardupilot that this GPIO pin is your BATTT9 analog read pin. As far as know BATT9_VOLT_PIN is the only pin for this purpose. But what is the meaning of these parameter options?
-1:Disabled 2:Pixhawk/Pixracer/Navio2/Pixhawk2_PM1 5:Navigator 13:Pixhawk2_PM2/CubeOrange_PM2 14:CubeOrange 16:Durandal 100:PX4-v1
Which one of this options i should set. Which one of these options refer to the which one of the mcu pins?
I will be very happy if you give any comment about this problems.
Best Regards
Is there anyone to help me
Hi Guys,
I solved this issue.
If you want to read analog data from 6.6V input, VOLT_PIN number should be 18.
This is same to Holybro durandal
