Read servo output using mission planner
Hello all of you.
I want to read throttle signal (servo3). I know that i can see it on “Tuning”, but i need it to use in real tieme during mission.
Do you know how can i read it?
I’m trying to read it with arduino. I conect to servo3 (throttle), but arduino don’t read properly the signal.
I think the hz from the servo (i use this for servo https://ardupilot.org/copter/docs/common-thecube-overview.html) is diferent of the arduino and it’s not posible to read the output signal.
you know how can i solve this problem or other way to read it?
Thank you
The mavlink messages give you that already:
https://mavlink.io/en/messages/common.html#RC_CHANNELS_RAW <- Reads channel inputs
https://mavlink.io/en/messages/common.html#SERVO_OUTPUT_RAW <- Reads channel outputs
Thank you.
I need to read it with out using mavlink, i need to read it from the servo output.
You say you want to use mission planner. Mission planner uses mavlink. Why do you say that you can not use mavlink?
If you are using standard RC PWM output (not dshot etc), an Arduino should be able to read the signal via the pulsein function or using interrupts.
The problem is not to use Mavlink, is that i need to do it with teensy.
Now i solve the problem.
Thank you
Yes, i use standard RC PWM, and i was using “pulsein()”.
But i have a mistake in code… i was using serial.begin(9600), and it need to be 115200.
Thank you!
Hi mate, could you give me a cable and share a bit of your light, it also happens to me, I’m trying from a teensy 4 to read the values of channel1 and channel3 to make a conversion of values and send them to other servos from the teensy and no I can read nothing, it only gives me a value of 0, what code have you used to read the PWM values, could you share it with me?
Thanks in advance
