Hello guys i’m tryning to read mavlink data using C# all the ressources that i found was in C, so i didn’t found something in c # can you help please
i’m new with mavlink and new in c# so really nead some codes to base on, i will arpeciate
Tnx
Mavlink does have C# bindings. Take a look at the documentation at https://github.com/ArduPilot/mavlink
There’s a few examples of people using Mavlink in C#:
-Mission Planner https://github.com/ArduPilot/MissionPlanner
-mavlink.net https://github.com/dsuarezv/mavlink.net
Hello again i’m having some problems in sending and receiving message.
Can you help please.
private void OpenSerialPort()
mySerialPort.BaudRate = 9600;
mySerialPort.Parity = Parity.None;
mySerialPort.StopBits = StopBits.One;
mySerialPort.DataBits = 8;
mySerialPort.Handshake = Handshake.None;
try
mySerialPort.DataReceived += SerialPortDataReceived;
mySerialPort.Open();
catch (Exception ex)
System.Diagnostics.Debug.WriteLine(ex.Message + ex.StackTrace);
private void SerialPortDataReceived(object sender, SerialDataReceivedEventArgs e)
var serialPort = (SerialPort)sender;
var data = serialPort.ReadByte();
Console.WriteLine("Data : "+data);
heartbeatData.Add((byte)data);
void Mavlink_request_data(byte id, byte rate)
MAVLink.MAVLinkMessage mAVLinkMessage = new MAVLink.MAVLinkMessage();
uint[] buffer = new uint[MAVLink.MAVLINK_MAX_PACKET_LEN];
MAVLink.MAVLinkParamList mAVLinkParams = new MAVLink.MAVLinkParamList();
MAVLink.Mavlink_request_data_stream_t mavlink_Request_Data_Stream_T = new MAVLink.Mavlink_request_data_stream_t
req_message_rate = rate,
req_stream_id = id,
start_stop = 1,
target_system = 1,
target_component = 1,
byte[] MVQRQT = new byte[6];
MVQRQT[0] = mavlink_Request_Data_Stream_T.target_system;
MVQRQT[1] = mavlink_Request_Data_Stream_T.target_component;
MVQRQT[2] = mavlink_Request_Data_Stream_T.req_stream_id;
MVQRQT[3] = (byte)mavlink_Request_Data_Stream_T.req_message_rate;
MVQRQT[5] = mavlink_Request_Data_Stream_T.start_stop;
byte[] packet = GeneratePacket(MVQRQT,(byte) MAVLink.MAVLINK_MSG_ID.REQUEST_DATA_STREAM);
SendPacket(packet);
byte[] GeneratePacket(byte[] packetData, byte msgID)
byte[] Packet = new byte[packetData.Length + 6 + 2];
Packet[0] = (byte)254;
Packet[1] = (byte)packetData.Length;
Packet[2] = (byte)1;
Packet[3] = (byte)255;
Packet[4] = (byte)1;
Packet[5] = msgID;
for (int n = 0; n < packetData.Length; n++)
Packet[6 + n] = packetData[n];
ushort checksum = MavlinkCRC.crc_calculate(Packet, Packet[1] + 6);
checksum = MavlinkCRC.crc_accumulate(MAVLink.MAVLINK_MESSAGE_CRCS[msgID], checksum);
byte ck_a = (byte)(checksum & 0xFF); ///< High byte
byte ck_b = (byte)(checksum >> 8); ///< Low byte
Packet[Packet.Length - 2] = ck_a;
Packet[Packet.Length - 1] = ck_b;
return Packet;
bool SendPacket(byte[] packetData)
try
if (mySerialPort.IsOpen)
mySerialPort.Write(packetData, 0, packetData.Length);
return true;
catch
return false;
return false;
private void button1_Click(object sender, EventArgs e)
Mavlink_request_data(200,1);
private void button2_Click(object sender, EventArgs e)
Mavlink_request_data(30, 1);
when i click on the button2 to have the altitude i have an error that say:
System.IO.FileLoadException : ‘Impossible de charger le fichier ou l’assembly ‘System.Runtime, Version=4.2.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’ ou une de ses dépendances. La définition trouvée du manifeste de l’assembly ne correspond pas à la référence de l’assembly. (Exception de HRESULT : 0x80131040)’
I’m not sure what that error is … I think it might be something to do with running the incorrect .net framework version.
hey i correct this error using object unsteed of byte in the parameters (it’s worked and i don’t know how :p).
i’m trying to read the mavlink msg but the only think i got is the heartbeat it have been one week i’m working on that can you help please this is my code.
can you check it please. i’m trying here to read attitude (id==30)
public int i;
MAVLink.MAVLinkMessage t = new MAVLink.MAVLinkMessage();
SerialPort mySerialPort = new SerialPort("COM14");
public static MAVLink.Mavlink_heartbeat_t hb = new MAVLink.Mavlink_heartbeat_t();
List<byte> heartbeatData = new List<byte>();
public Form1()
InitializeComponent();
OpenSerialPort();
mySerialPort.BaudRate = 57000;
try
Mavlink_request_data(30, 0x02);//send request to read attitude id==30
Console.WriteLine("Data : " + data);
MAVLink.Mavlink_request_data_stream_t req = new MAVLink.Mavlink_request_data_stream_t
target_system = 1,
start_stop = 1, // start
req_stream_id = (byte)id // id
// send each one twice.
GeneratePacket((byte)MAVLINK_MSG_ID.REQUEST_DATA_STREAM, req);
void GeneratePacket(byte messageType, object indata)
if (!mySerialPort.IsOpen)
return;
byte[] data;
data = MavlinkUtil.StructureToByteArray(indata);
//Console.WriteLine(DateTime.Now + " PC Doing req "+ messageType + " " + this.BytesToRead);
byte[] packet = new byte[data.Length + 6 + 2];
packet[0] = 254;
packet[1] = (byte)data.Length;
packet[2] = (byte)0; //numero de la sequence ici
packet[3] = 255; // this is always 255 - MYGCS
packet[4] = (byte)MAV_COMPONENT.MAV_COMP_ID_MISSIONPLANNER;
packet[5] = messageType;
int i = 6;
foreach (byte b in data)
packet[i] = b;
i++;
ushort checksum = MavlinkCRC.crc_calculate(packet, packet[1] + 6);
checksum = MavlinkCRC.crc_accumulate(MAVLINK_MESSAGE_CRCS[messageType], checksum);
packet[i] = ck_a;
i += 1;
packet[i] = ck_b;
i += 1;
mySerialPort.Write(packet, 0, i);
