Hi, I’m new to this and having trouble setting up my APM 2.8. When i first calibrated my board it was fine but now when i try to select a flight mode using the toggle switch on my spectrum dx7 nothing happens but moving the throttle stick up and down controls both the throttle and the flight mode (as indicated on the setup screen). i’m fairly sure that everything is connected correctly, I.E #5 on the board to aux on the receiver. Any ideas would be greatly appreciated. thanks
@Clive Weston,
What version of the ArduCopter firmware are you using?
Regards,
TCIII GM
OK, sorry about that. I think its Arducopter V3.2.1. Its the firmware that is on the mission planner when I downloaded it. Appreciate you taking the time to help me with this, I had no idea these things were so technical.
