Is there any other way to configure OSD without using[color=#000080][color=#804080][color=#800000][/color][/color][/color] FTDI cable i.e. using apm 2.6 through its usb connection.
Please help me out with this as its urgent.
Enclose some link or video for the suggestions you can send.
Hi Aniket92,
AFAIK there is no way to configure the miniOSD through the APM’s USB port.
The miniOSD uses a serial communication, is powered with 5V between GND and +5V pins and the RX and TX are 3.3V, the FTDI cable converts this communication to USB.
So even if your computer has a serial port (rs232) a TTL converter is needed between the computer port and the miniOSD.
