RE: Cross-Compilation on Debian for ArduPilot/Copter ./waf configure --board=blue
I am on WSL2 Debian box and trying to cross-compile ArduPilot for the BBBlue.
I have come across some issues.
IOError: [Errno 2] No such file or directory: '/home/xxxxxxx/ardupilot/libraries/AP_Math/edc.h'
Mostly…when compiling the source of ardupilot completely w/ one swoop of ./waf copter, I receive the above error.
Seth
P.S. I have looked around for the file and have come up empty. If you know how to compile on WSL2, please advise. Thank you for now. If there are no cures for WSL2, I will use a Debian or Ubuntu machine.
Okay…so:
For Copter-4.0, one would just need to run the ubuntu set up file
even when on Debian Buster.
and…
And to not install the STM toolchain for the BBBlue when cross-compiling is key.
So, when on the BBBlue, use these commands to compile natively (boring) and it will work:
First clone the library from github.com/ArduPilot/ardupilot
  • sudo apt install make gcc g++ python3-dev python3-pip python3-lxml pkg-config python3
  • cd arducopter
  • git checkout Copter-4.0
  • git submodule update --init --recursive
  • python3 waf configure --board=blue
  • python3 waf copter
That will natively compile the Copter-4.0 on your Linux SBC…
Seth
P.S. If anyone has any questions, ask!
And for cross-compilation, here are some easy steps:
git clone GitHub - ArduPilot/ardupilot: ArduPlane, ArduCopter, ArduRover, ArduSub source
sudo your favorite text editor ardupilot/Tools/environment_install/install-prereqs-ubuntu.sh
for instance when in /ardupilot/Tools/environment_install, sudo nano install-prereqs-ubuntu.sh
There are a couple of things to change out if using a Debian Distro, i.e. WSL2 or a real Debian machine.
In that file, the install-prereqs-ubuntu.sh, change the file to be similar to this:
#!/bin/bash
echo "---------- $0 start ----------"
set -e
set -x
if [ $EUID == 0 ]; then
    echo "Please do not run this script as root; don't sudo it!"
    exit 1
fi
OPT="/opt"
# Ardupilot Tools
ARDUPILOT_TOOLS="Tools/autotest"
ASSUME_YES=false
QUIET=false
sep="##############################################"
OPTIND=1  # Reset in case getopts has been used previously in the shell.
while getopts "yq" opt; do
    case "$opt" in
            exit 1
        y)  ASSUME_YES=true
        q)  QUIET=true
    esac
done
APT_GET="sudo apt"
if $ASSUME_YES; then
    APT_GET="$APT_GET --assume-yes"
fi
if $QUIET; then
    APT_GET="$APT_GET -qq"
fi
# update apt package list
$APT_GET update
function package_is_installed() {
    dpkg-query -W -f='${Status}' "$1" 2>/dev/null | grep -c "ok installed"
function heading() {
    echo "$sep"
    echo $*
    echo "$sep"
# Install lsb-release as it is needed to check Ubuntu version
if ! package_is_installed "lsb-release"; then
    heading "Installing lsb-release"
    $APT_GET install lsb-release
    echo "Done!"
fi
# Checking Ubuntu release to adapt software version to install
RELEASE_CODENAME=$(lsb_release -c -s)
PYTHON_V="python3"  # starting from ubuntu 20.04, python isn't symlink to default python interpreter
PIP=pip3
if [ ${RELEASE_CODENAME} == 'xenial' ]; then
    SITLFML_VERSION="2.3v5"
    SITLCFML_VERSION="2.3"
elif [ ${RELEASE_CODENAME} == 'disco' ]; then
    SITLFML_VERSION="2.5"
    SITLCFML_VERSION="2.5"
elif [ ${RELEASE_CODENAME} == 'eoan' ]; then
elif [ ${RELEASE_CODENAME} == 'focal' ] || [ ${RELEASE_CODENAME} == 'ulyssa' ]; then
    PYTHON_V="python3"
    PIP=pip3
elif [ ${RELEASE_CODENAME} == 'bullseye' ] || [ ${RELEASE_CODENAME} == 'hirsute' ]; then
    PYTHON_V="python3"
    PIP=pip3
elif [ ${RELEASE_CODENAME} == 'trusty' ]; then
    SITLFML_VERSION="2"
    SITLCFML_VERSION="2"
else
    # We assume APT based system, so let's try with apt-cache first.
    SITLCFML_VERSION=$(apt-cache search -n '^libcsfml-audio' | cut -d" " -f1 | head -1 | grep -Eo '[+-]?[0-9]+([.][0-9]+)?')
    SITLFML_VERSION=$(apt-cache search -n '^libsfml-audio' | cut -d" " -f1 | head -1 | grep -Eo '[+-]?[0-9]+([.][0-9]+)?')
    # If we cannot retrieve the number with apt-cache, try a last time with dpkg-query
    re='^[+-]?[0-9]+([.][0-9]+)?$'
    if ! [[ $SITLCFML_VERSION =~ $re ]] || ! [[ $SITLFML_VERSION =~ $re ]] ; then
        # Extract the floating point number that is the version of the libcsfml package.
        SITLCFML_VERSION=$(dpkg-query --search libcsfml-audio | cut -d":" -f1 | grep libcsfml-audio | head -1 | grep -Eo '[+-]?[0-9]+([.][0-9]+)?')
        # And same for libsfml-audio.
        SITLFML_VERSION=$(dpkg-query --search libsfml-audio | cut -d":" -f1 | grep libsfml-audio | head -1 | grep -Eo '[+-]?[0-9]+([.][0-9]+)?')
    fi
fi
# Check whether the specific ARM pkg-config package is available or whether we should emulate the effect of installing it.
# Check if we need to manually install libtool-bin
ARM_PKG_CONFIG_NOT_PRESENT=0
if [ -z "$(apt-cache search -n '^pkg-config-arm-linux-gnueabihf')" ]; then
    ARM_PKG_CONFIG_NOT_PRESENT=$(dpkg-query --search pkg-config-arm-linux-gnueabihf |& grep -c "dpkg-query:")
fi
if [ "$ARM_PKG_CONFIG_NOT_PRESENT" -eq 1 ]; then
    INSTALL_PKG_CONFIG=""
    # No need to install Ubuntu's pkg-config-arm-linux-gnueabihf, instead install the base pkg-config.
    sudo apt install pkg-config
    if [ -f /usr/share/pkg-config-crosswrapper ]; then
        # We are on non-Ubuntu so simulate effect of installing pkg-config-arm-linux-gnueabihf.
        sudo ln -s /usr/share/pkg-config-crosswrapper /usr/bin/arm-linux-gnueabihf-pkg-config
    #else
        #echo "Warning: unable to link to pkg-config-crosswrapper"
    fi
else
    # Package is available so install it later.
    INSTALL_PKG_CONFIG="pkg-config-arm-linux-gnueabihf"
fi
# Lists of packages to install
BASE_PKGS="build-essential ccache g++ gawk git make wget"
PYTHON_PKGS="future lxml pymavlink MAVProxy pexpect flake8 geocoder"
# add some Python packages required for commonly-used MAVProxy modules and hex file generation:
if [[ $SKIP_AP_EXT_ENV -ne 1 ]]; then
  PYTHON_PKGS="$PYTHON_PKGS pygame intelhex"
fi
ARM_LINUX_PKGS="g++-arm-linux-gnueabihf $INSTALL_PKG_CONFIG"
# python-wxgtk packages are added to SITL_PKGS below
SITL_PKGS="libtool libxml2-dev libxslt1-dev ${PYTHON_V}-dev ${PYTHON_V}-pip ${PYTHON_V}-setuptools ${PYTHON_V}-numpy ${PYTHON_V}-pyparsing ${PYTHON_V}-psutil"
# add some packages required for commonly-used MAVProxy modules:
if [[ $SKIP_AP_GRAPHIC_ENV -ne 1 ]]; then
  SITL_PKGS="$SITL_PKGS xterm ${PYTHON_V}-matplotlib ${PYTHON_V}-serial ${PYTHON_V}-scipy ${PYTHON_V}-opencv libcsfml-dev libcsfml-audio${SITLCFML_VERSION} libcsfml-dev libcsfml-graphics${SITLCFML_VERSION} libcsfml-network${SITLCFML_VERSION} libcsfml-system${SITLCFML_VERSION} libcsfml-window${SITLCFML_VERSION} libsfml-audio${SITLFML_VERSION} libsfml-dev libsfml-graphics${SITLFML_VERSION} libsfml-network${SITLFML_VERSION} libsfml-system${SITLFML_VERSION} libsfml-window${SITLFML_VERSION} ${PYTHON_V}-yaml"
fi
if [[ $SKIP_AP_COV_ENV -ne 1 ]]; then
  # Coverage utilities
  COVERAGE_PKGS="lcov gcovr"
fi
# ArduPilot official Toolchain for STM32 boards
function install_arm_none_eabi_toolchain() {
  # GNU Tools for ARM Embedded Processors
  # (see https://launchpad.net/gcc-arm-embedded/)
  ARM_ROOT="gcc-arm-none-eabi-6-2017-q2-update"
  ARM_TARBALL="$ARM_ROOT-linux.tar.bz2"
  ARM_TARBALL_URL="https://firmware.ardupilot.org/Tools/STM32-tools/$ARM_TARBALL"
  if [ ! -d $OPT/$ARM_ROOT ]; then
        cd $OPT;
        heading "Installing toolchain for STM32 Boards"
        echo "Downloading from ArduPilot server"
        sudo wget $ARM_TARBALL_URL
        echo "Installing..."
        sudo tar xjf ${ARM_TARBALL}
        echo "... Cleaning"
        sudo rm ${ARM_TARBALL};
  fi
  echo "Registering STM32 Toolchain for ccache"
  sudo ln -s -f $CCACHE_PATH /usr/lib/ccache/arm-none-eabi-g++
  sudo ln -s -f $CCACHE_PATH /usr/lib/ccache/arm-none-eabi-gcc
  echo "Done!"
function maybe_prompt_user() {
        return 0
    else
        read -p "$1"
        if [[ $REPLY =~ ^[Yy]$ ]]; then
            return 0
        else
            return 1
        fi
    fi
heading "Add user to dialout group to allow managing serial ports"
sudo usermod -a -G dialout $USER
echo "Done!"
# Add back python symlink to python interpreter on Ubuntu >= 20.04
    BASE_PKGS+=" python-is-python3"
    SITL_PKGS+=" libpython3-stdlib" # for argparse
else
  SITL_PKGS+=" python-argparse"
fi
# Check for graphical package for MAVProxy
    SITL_PKGS+=" python3-wxgtk4.0"
    SITL_PKGS+=" fonts-freefont-ttf libfreetype6-dev libjpeg62-turbo-dev libpng16-16 libportmidi-dev libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev libsdl1.2-dev"  # for pygame
    SITL_PKGS+=" fonts-freefont-ttf libfreetype6-dev libjpeg8-dev libpng16-16 libportmidi-dev libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev libsdl1.2-dev"  # for pygame
  elif apt-cache search python-wxgtk3.0 | grep wx; then
      SITL_PKGS+=" python-wxgtk3.0"
  else
      # we only support back to trusty:
      SITL_PKGS+=" python-wxgtk2.8"
      SITL_PKGS+=" fonts-freefont-ttf libfreetype6-dev libjpeg8-dev libpng12-0 libportmidi-dev libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev libsdl1.2-dev"  # for pygame
  fi
fi
# Check if we need to manually install realpath
RP=$(apt-cache search -n '^realpath$')
if [ -n "$RP" ]; then
    BASE_PKGS+=" realpath"
fi
LBTBIN=$(apt-cache search -n '^libtool-bin')
if [ -n "$LBTBIN" ]; then
    SITL_PKGS+=" libtool-bin"
fi
# Install all packages
$APT_GET install $BASE_PKGS $SITL_PKGS $PX4_PKGS $ARM_LINUX_PKGS $COVERAGE_PKGS
$PIP install --user -U $PYTHON_PKGS
if [[ -z "${DO_AP_STM_ENV}" ]] && maybe_prompt_user "Install ArduPilot STM32 toolchain [N/y]?" ; then
    DO_AP_STM_ENV=1
fi
heading "Removing modemmanager package that could conflict with firmware uploading"
if package_is_installed "modemmanager"; then
    $APT_GET remove modemmanager
fi
echo "Done!"
CCACHE_PATH=$(which ccache)
if [[ $DO_AP_STM_ENV -eq 1 ]]; then
fi
heading "Check if we are inside docker environment..."
IS_DOCKER=false
if [[ -f /.dockerenv ]] || grep -Eq '(lxc|docker)' /proc/1/cgroup ; then
    IS_DOCKER=true
fi
echo "Done!"
SHELL_LOGIN=".profile"
if $IS_DOCKER; then
    echo "Inside docker, we add the tools path into .bashrc directly"
    SHELL_LOGIN=".bashrc"
fi
heading "Adding ArduPilot Tools to environment"
SCRIPT_DIR=$(dirname $(realpath ${BASH_SOURCE[0]}))
ARDUPILOT_ROOT=$(realpath "$SCRIPT_DIR/../../")
exportline="export PATH=$OPT/$ARM_ROOT/bin:\$PATH";
grep -Fxq "$exportline" ~/$SHELL_LOGIN 2>/dev/null || {
    if maybe_prompt_user "Add $OPT/$ARM_ROOT/bin to your PATH [N/y]?" ; then
        echo $exportline >> ~/$SHELL_LOGIN
        eval $exportline
    else
        echo "Skipping adding $OPT/$ARM_ROOT/bin to PATH."
    fi
exportline2="export PATH=$ARDUPILOT_ROOT/$ARDUPILOT_TOOLS:\$PATH";
grep -Fxq "$exportline2" ~/$SHELL_LOGIN 2>/dev/null || {
    if maybe_prompt_user "Add $ARDUPILOT_ROOT/$ARDUPILOT_TOOLS to your PATH [N/y]?" ; then
        echo $exportline2 >> ~/$SHELL_LOGIN
        eval $exportline2
    else
        echo "Skipping adding $ARDUPILOT_ROOT/$ARDUPILOT_TOOLS to PATH."
    fi
if [[ $SKIP_AP_COMPLETION_ENV -ne 1 ]]; then
exportline3="source $ARDUPILOT_ROOT/Tools/completion/completion.bash";
grep -Fxq "$exportline3" ~/$SHELL_LOGIN 2>/dev/null || {
    if maybe_prompt_user "Add ArduPilot Bash Completion to your bash shell [N/y]?" ; then
        echo $exportline3 >> ~/.bashrc
        eval $exportline3
    else
        echo "Skipping adding ArduPilot Bash Completion."
    fi
fi
exportline4="export PATH=/usr/lib/ccache:\$PATH";
grep -Fxq "$exportline4" ~/$SHELL_LOGIN 2>/dev/null || {
    if maybe_prompt_user "Append CCache to your PATH [N/y]?" ; then
        echo $exportline4 >> ~/$SHELL_LOGIN
        eval $exportline4
    else
        echo "Skipping appending CCache to PATH."
    fi
echo "Done!"
if [[ $SKIP_AP_GIT_CHECK -ne 1 ]]; then
  if [ -d ".git" ]; then
    heading "Update git submodules"
    cd $ARDUPILOT_ROOT
    echo "Done!"
  fi
fi
echo "---------- $0 end ----------"
You can see the changes I made to handle the WSL2 Debian for bullseye or Debian machine Distros.
So now…
cd ~/arducopter
sudo git checkout Copter-4.1
sudo python3 waf configure --board=blue
sudo python3 waf copter
Then, on your WSL2 instance of Debian or a real Debian machine, perform these steps to publish the binary onto your BBBlue.
In your ~/arducopter directory, use this command.
sudo python3 configure --board=blue --rsync-dest debian@192.168.7.2:/home/debian
This will create the correct way to install your binary. Now, we need to upload it by performing this command but you need to be in the /ardupilot/build/blue/ directory when running the below command.
sudo python3 ../../waf --target bin/arducopter --upload
This will install/upload the binary to the BBBlue in your /home/debian/usr/bin/ directory.
You can see the new usr/ directory made after the script finishes.
Seth
P.S. If you find that these requirements are incorrect, please contact me.
