I seem to be getting many compilation errors while compiling on a 32-bit arm computer. I am compiling RC 4.0 from ArduPilot on the BBBlue to see if things work out or if there are errors to be found.
Anyway…there is a better way. I am not taking that route right now.
Are there any plans to use waf w/ Python3 to compile RC 4.0 on armhf boards?
Seth
P.S. I see some libraries are still only compatible with Python2 from a guide I have been following. There is a new image available online from the beagleboard.org/latest-images people. The image is good. I am just seeing error after error and wondering if I should downgrade to an older RC or if anyone else is having compilation issues, too.
@stephendade: Here are some errors during the current compilation of RC 4.0 w/ waf from python2. I tried w/ python3 but I found that there were more errors like these during compilation…
In file included from ../../libraries/AC_Avoidance/AP_OAVisGraph.h:4,
from ../../libraries/AC_Avoidance/AP_OADijkstra.h:7,
from ../../libraries/AC_Avoidance/AP_OAPathPlanner.h:8,
from ../../libraries/AR_WPNav/AR_WPNav.h:6,
from ../../libraries/AR_WPNav/AR_WPNav.cpp:18:
../../libraries/AP_Common/AP_ExpandingArray.h: In instantiation of 'const T&
AP_ExpandingArray<T>::operator[](uint16_t) const [with T = AP_OAVisGraph::VisGraphItem; uint16_t =
short unsigned int]':
../../libraries/AC_Avoidance/AP_OAVisGraph.h:53:71: required from here
../../libraries/AP_Common/AP_ExpandingArray.h:107:16: warning: cast from
'AP_ExpandingArrayGeneric::chunk_ptr_t' {aka 'unsigned char*'} to 'const
AP_OAVisGraph::VisGraphItem*' increases required alignment of target type [-Wcast-align]
return (const T &)(chunk_ptrs[chunk_num][chunk_index]);
I am seeing these types of errors but it seems the build persists w/out incident. I tried to set up this idea:
sudo apt-get install g++ make pkg-config python python-dev python-lxml python-pip
sudo pip install future
git clone https://github.com/ArduPilot/ardupilot
cd ardupilot
git branch -a # <-- See all available branches.
git checkout Copter-3.6 # <-- Select one of the ArduCopter branches.
git submodule update --init --recursive
./waf configure --board=blue # <-- BeagleBone Blue.
./waf
sudo cp ./build/blue/bin/a* /usr/bin/ardupilot
P.S. If you see what I am doing incorrectly to receive the baro not initialised error when setting up Mavlink, please apply some knowledge here. I sure could use some insight or guidance.
Hello to @stephendade and Anyone Else Following Along,
This file needs to be typed up w/ my development desktop or the BBBlue IP Address?
sudo nano /etc/default/ardupilot
TELEM1"-C /dev/ttyS1"
TELEM2="-A udp:<target IP address>:14550"
GPS="-B /dev/ttyO2"
I have compiled the source of ardupilot/arducopter correctly. It is showing that the service works and the user LED is flashing red.
Seth
P.S. Where it states above, what exactly does target IP address mean? I am asking b/c I am trying to connect to Mission Planner on the Windows 10 edition.
That’s the network IP address of the windows computer, probably 192.168.something.something.
Open a command prompt in windows and type “ipconfig”, and it’ll show. You want the IPv4 address.
Well, I got the calibration done b/c of this person I met online at Freenode #beagle.
Anyway, the BBBlue needs to be on its edge and not turned left like a left turn on a plane. Blah. Anyway, the calibration steps have concluded and are done. Time to fly, soon.
@De_Funct - I am just about to start my journey with BBBlue. I found it frustrating that there was not enough documentation available on TI’s website on how to use BBBlue. I have followed many discussions on this site since last year reg. QuadCopter on BBBlue - and your discussions have shown up very prominently. While I start now, I will try to read your previous messages to gather/learn as much as I can. Would it possible for your to provide some guidance - and can I reach out to you for question?
