Hi all,
can you fix this?
Log link below and I can get you way more logs, but it all shows the same and since I saw no fix in the release notes I thought I will put it inhere.
on RC9-14
If RCx_TRIM = 1500 (or anything else) AND RCx_FUNCTION=0 the output PWM is 0.
I believe it should be 1500 in this case. (i have to manually set before each flight from MP)
If RCx_TRIM = 1500 (or anything else) AND RCx_FUNCTION=10 the output PWM is correct
In the Arduplane 3.5 version it works like it should so it should be an easy fix…
More to the background:
it is an X8 copter
on RC9 i have the cam trigger
on RC10 cam shut down+zoom reset
on RC11 cam zoom in+out
on RC12 cam other camra control function
on RC13 cam gimbal tilt
https://drive.google.com/file/d/0Bz9RWJnTBrzIa05FYXNpRnJ5YlU/view?usp=sharing
