Just connecting an oscilloscope, so I should be able to see the signal, no? Just in case I did connect +5Volts to the rail to be sure, to be sure… Well my RC6 is “eaten away” by the pixhawk !
Yes, David the safety switch was pressed. Thank you.
Not to worry. Just forgetting about RC6 pass-through. Will use a Frsky X8R in 16 channel mode and that would solve the problem.
Thank you both iseries and David_Boulanger.
Henrik - I have passthru working on 2 of my models - both running different pixhawk versions (AUAV-X2, and Pixhawk Lite), but in my case I never tested this on Ch6 - I always use ch9 - ch14 only (which correspond with the AUX connectors on the servo rail). One example is on my AUAV-X2 - I have RC9_FUNCTION = 1 and ch9 is output on the servo rail to a servo I am using to tilt my board camera. On my Plane, I have the Pixhawk Lite configured with RC10_FUNCTION = 1 and my Ch10 controls my Runcam HD2 via its RC cable, also RC9_FUNCTION = 1 on this plane and Ch9 controls a camera switch - both of these directly from the AUX outputs. On my big hexa however the only AUX port I am using is for landing gear and that is not configured for passthru (there is a seperate landing gear option for that). Instead on this hexa, I chose to configure the X8R in mode 4 (configure this by shorting ch1-2 and ch3-4 with jumpers whilst binding) and access the servo headers directly (these now output on ch9-16) to control my gimbal. I’m thinking that maybe there is an issue with ch6, and you could maybe try 12 or higher, just as a test?
