RC Telemetry - Only getting GPS Sensor
Hey All,
I have a Matek F765 and R9M connected to UART - TX4 (Serial 6) and using FPORT. I am able to control my surfaces so the radio link is working however when viewing sensors on my transmitter, I only get GPS.
Any ideas? I havent updated OpenTX for a while so I’m wondering if it is that?
Using the following settings;
  • SERIALx_PROTOCOL =23
  • SERIALx_OPTIONS = 7 (invert TX/RX,Half Duplex)
  • RSSI_TYPE =3
:slight_smile:
Arm the plane/ardupilot and it will work and show all the sensors.
Without arming it will only discover GPS sensors.
I have tried arming and it does not discover anymore sensors?
In that case, sorry I have no solution. If GPS sensor is discovering, that means Fport settings and other config is ok. I would probably check other board.
Strangely yapuu is working with all of the sensors even though only GPS is showing up. Weird, but at least it is working
