Hello community,
Hope you are all doing well.
This is going to be long so I apologise in advance, but pls take the time to read it since it may pose a safety risk…
I have been trying to setup my original Pixhawk 1 to work with a joystick through 4G network.
4G and companion computer are working nicely.
However I cannot seem to get the RC overrides to work correctly. It always seems like the RC keeps working even if Joystick is ENABLED
When Joystick is enabled with RC OFF it works like expected… I can see all inputs on the RC calibration tab. Also GCS failsafe works Fine.
When RC is ON and joystick is NOT enabled it again works like it should.
When Joystick is ENABLED and I turn on RC weird things start happening…
Firstly it regains control and by-passes the override BUT ! (This is the dangerous part…) NOT entirely.
On the RC calibration tab I can see the RC inputs but they momenterily (<1s) switch to the inputs of the Joystick! It seems like there is a conflict and BOTH RC and Joystic are simulatanusly sending commands to Pixhawk! This is very dangerous.
Another Issue that supports the existance of a simultaneous conflict is that when having the Joystick ENABLED and RC ON if I turn off the RC it sends pixhawk in an infinate loop between RC failsafe and Failsafe Cleared. Until I either disable the Joystick or turn on again the RC.
(This loop happens so fast that the FC may not trigger an actual failsafe but instead stay in a Limbo of no control!) Please take a look at the video (sound On):
I’m well aware that many people are using it without issues, but clearly there is something in my setup that triggers this behaviour, that should never -ever happen.
My setup: Pixhawk 1(AC 4.0.3) , Crossfire nano RX (On telemetry 2), Mission Planner 1.3.70 and 1.3.71, SYSID_MYGCS = 255
Lastly here’s my full Parameters file: X8_4.03uavcast_rctimerprops_3.param (18.3 KB)
Thanks in advance to all
George
