I’m using Pixhawk 2.4.8 with Arducopter 4.1.2
- If I upload Arducopter (full code), with my RC receiver SBUS connected, everything works fine. I can see the signals as I move the Transmitter stick.
- If I run RCInput, RC_Channel, RCInputToRCOuput examples, the codes compile correctly as they are, and run when my transmitter is off. However, when I turn it on, it completely stops spitting out anything on the serial, and basically freezes the serial port entirely. I have to actually disconnect and connect it back so that is does something reasonable. After this, again, I can upload normal arducopter and see the signals perfectly, but the RC examples don’t run, all other examples run fine.
