Hi everyone!
I have a rc combat wing which has 2 elevons (each working with 1 digital SERVO), is it possible to control these with a digital or analog gimbal (https://www.frsky-rc.com/product/mc12p/)) connected and do the mixing through a flight controller, pixhawk or any board by ardupilot?
All connections from the wing to the gimbal should be via cable (not wireless 2.4ghz)
tasks will be:
elevon mixing (of 2 servos… in future maybe up to 4)
trims for the elevon
exponential movement of the control gimbal
the combat wing will be tested in a wind tunnel due to some factors we want the setup to not be wireless (traditional way of Transmitter to receiver)
@Allister thanks, my question is if I can connect a gimbal to the ardupilot and from there to the servos all via cable!? no wireless connections what so ever!?
You could do a joystick on the GCS: Joystick/Gamepad — Plane documentation and then a USB connection from the GCS to the flight controller. The GCS to the flight controller is typically some kind of serial connection, either via USB or a serial port. There may be limitations on how long the wires can be but in principal it will work.
